Segfault when referencing a removed action via Python #39600
2 Participants
Reference: blender/blender#39600
Arch Linux, Nvidia Quadro K5000M
Broken: master -
2dedf2a
Blender crashes if you try to reference an action datablock after it's been removed via Python.
Use the attached .blend file
Also attached is a gdb backtrace
action_ref-segfault.blend
action_ref-segfault_backtrace.txt
Added subscriber: @JasonvanGumster
Added subscribers: @ideasman42, @LukasTonne
Unfortunately there is no good way to support explicit deletion of ID data blocks from python ...
ID.user_clear
simply sets the user count to 0 - without any kind of check. I'm not sure if there is a legit use case for this function, but it has to be used with extreme care and should be avoided whenever possible.bpy.data.***.remove
is even more dangerous, it directly deletes ID blocks from the library, but also doesn't clear any references to these blocks in the general case, leaving you with dangling pointers and invalid python objects (such as theaction
variable in your case)According to @ideasman42 there is no proper way to support these things efficiently. There is a build option WITH_PYTHON_SAFETY which would at least keep python variables valid, but still doesn't solve issues with
remove()
function calls.Some data blocks have "unlink" functionality build into their freeing functions (Object, Group, Text, ...) which should help keep the C pointer sane, but this is not universally implemented (in particular Action doesn't do it yet).
TL;DR: Never ever use bpy.data.xxx.remove() unless you're absolutely sure what you are doing (basically: be sure there are no references to that data block left). Sorry, it's a difficult technical issue :(
