Building RUN_TESTS fails a number of tests #39788
2 Participants
Reference: blender/blender#39788
Win 8.1 x64
Current git build
Failed tests:
2:script_load_addons
3:script_load_modules
6:import_obj_cube
7:import_obj_nurbs_cyclic
8:import_obj_makehuman
11:export_obj_all_objects
15:export_ply_cube_all_data
16:export_ply_suzanne_all_data
21:export_stl_cube_all_data
22:export_stl_suzanne_all_data
23:export_stl_vertices
24:import_x3d_cube
25:import_x3d_teapot
26:import_x3d_suzanne_material
27:export_x3d_cube
28:export_x3d_nurbs
29:export_x3d_all_objects
31:import_3ds_hierarchy_lara
32:import_3ds_hierarchy_greek_trireme
35:export_3ds_all_objects
36:export_fbx_cube
37:export_fbx_nurbs
38:export_fbx_all_objects
Running the Visual Studio 2013 RUN_TESTS fails a number of tests. The log is here LastTest.log
This is with the Release / ReleaseWithDebug info builds.
With the Debug build the failures are worse, I suspect because the right python files are not being copied across, so things like _socket are not found. This is presumably a CMake configuration issue.
Added subscriber: @jrp
Added subscriber: @mont29
I) Please do not assign bug yourself, this is a dev’s task.
II) Autotest failing is not considered a bug. These are devs tools, and it’s known issue some of them fail currently, rather use bf-committer ML or IRC for such non-end-user issues.
