Cannot Play Render Animation #39789
8 Participants
Reference: blender/blender#39789
Win7, GTX650
Broken: 2.70.2,
Worked: 2.70
Cannot play any rendered animation. Neither by using CTRL+F11 nor by using the button on Menu->Render->Play Render Animation. I tried different versions of Blender (all above 2.70). One called "File 'C:\0000.png' not found". I use an other path for saving my render. There must be the problem.
I've removed the application data, tried out with factory settings, started Blender as Administrator - nothing has worked. I also moved the render results to C: but it also not worked. Now I am sure, that this is a bug.
Just render any animation (openGL or other way) and try to preview with a 2.70.2 (maybe also 2.70.1). I use builds from graphicall.org, e.g.
4ed16bc
.Greets, Hero
Confirmed, I get "wm_main_playanim_intern: 'C:\tmp\0001.png' not an image file"
Added subscriber: @Sergey
@ThomasDinges, are there files in the folder? Can you open them with an image editor?
Added subscriber: @LukasTonne
Seems to work fine on linux (/tmp/0001.png etc). Probably a windows issue?
Looks like error in
int
->bool
cleanup, but worked in Linux.Fixed
863352dfdc
Added subscriber: @PauloRJRJ
Sorry, but this bug is back in 2.81.16.... I can't play my animations because it tries to write to C:\tmp, which does not exist. I also can't create it due to IT policies. What should I do other than mobilize my IT department just to create a directory?
Added subscriber: @ChristopherAnderssarian
@PauloRJRJ You need to change the render output location to something you are allowed to write to.
Blender will then read the rendered file(s) from that location.
True! It's there. Thank you, sir. :-)
Added subscriber: @austin.m.d.elliott
Ok, I have permissions to write to the directory and I get File 'C:\Users\myusernamehere\output0001', where are the double slashes coming from? I can't find a direct answer to the exact problem and mine might be a different issue...
Hello, Austin, the double backslash is a good practice when setting Windows paths. Some programs written in C-like languages treat the backslash as an escape character. For example 'C:\temp\etc.txt' usually result in mysterious bugs because the '\t' is an escape sequence for the tab character.
