Cycles render different between GPU and CPU on transparent shader #39885
Reference: blender/blender#39885
In most cases, Cycles render is exactly identical be it on GPU or CPU. I noticed a slight difference when rendering on a home-made 3 server farm, 2 with GPU, 1 with CPU, it gave a flickering effect because frames made with CPU are a bit different. I narrowed it down to the transparent shader, as the attached file bug-transparent-cycle.blend demonstrates. Render it once on GPU, then again on CPU with another slot and compare. Now I don't know if it's an absolute rule that Cycles should render identically on GPU and CPU, is it ?
Added subscriber: @PatriceBertrand
I tested the file on a 2.68RC1, and the 2 renders are identical, so something happened between 2.68 and 2.70, I don't have many versions at hand to try.
My specs: Windows 64bits, GeForce GTX560Ti.
Added subscriber: @mont29
This looks like a duplicate of #39761?
Not exactly a duplicate, since #39761 states that cycles render in view port is not right, while it is correct in a real render. In my case, it is the full render that is different.
Added subscriber: @lopataasdf
This file has (near) overlapping faces, which is always problematic for raytracers. Here different float precision on the GPU and CPU makes the results different. The suggestion for now is to avoid this case and increase the distance a bit. We might improve the accuracy in the future, but for now it's not considered a bug.
Thank you for your analysis. Still it seems strange to call this anything else than bug. Particularly since it worked fine before. I do agree it is not a major problem, it is not very often that cpu and gpu are used together and must match. I think using shrinkwrap with a very small offset is pretty commonplace.
