Crash on recalculate normals / unexpected looptools result #39979
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#39979
Mac 10.6.8
2.4 Ghz Intel Core Duo
GeForce 8600M GT
Hash 6babb4d
2014-04-23
07:13
Loop tool result inconsistent. Recalculating normals causes segmentation fault and crash of the application.
Add Mesh Extra objects Polysphere.
Edit Mode delete centre vertex in either + or - x direction.
Select Resulting edge loop, W loop tools circle.
Select all and recalculate normals results in a crash for me.
looperror.blend
Added subscriber: @esskay
Added subscriber: @totoro-4
Partially confirmed with Blender 2.70a official (Hash: f93bc76) Ubuntu 14.04 64bit: no crash but the loop vertices are deleted just like on the picture. If you delete the central vertex in the Y or Z direction it works normally.
Another interesting: after the loop deleted, I cannot use the ctrl+rmb selection on the new hole edge correctly. The middle two edges are not selected. If you select this loop, and make a face on them, the result is also weird.
EDIT: I've tried this with a simple subdivided plane and the result of the circle command is heavily distorted if the circle is in the y,z plane. What if the vertex coordinate gets a NAN or INF?
Added subscriber: @mont29
What is “W loop tools circle.”, does it comes from an addon?
uh, silly me, of course it is :/
Mmmh… can’t reproduce with latest master, mind testing a recent build from our buildbot?
091f13a buildbot
On the test file attached above I can still reproduce this.
Yeah, actually, could reproduce the crash, but only from that file… would need to check the mesh is valid first.
To be more precise;
maybe the difference with that file is that the polysphere is translated in edit mode a unit in the z direction first (a habit of mine) before deleting the vertex? I will check later.
I think this happens only if the resulting circle is in the y-z plane. If you move any of the vertices slightly before, it works good. I also think it happens because the x coordinates of the calculated vertices gets an extremely big value or maybe NaN or Inf.
Yes indeed, circle generates NaN’s in this case… Bart, reassinging to you. ;)
Thanks for the report. I'll look into it.
This issue was referenced by
6b57e3ed43
Closed by commit
6b57e3ed43
.This issue was referenced by ddf16697699b98ee00e180446980f85404bd9da9
