Cycles renders invisible faces or Blender does not display them #40125
Reference: blender/blender#40125
win7 64 i7 gtx titan
blender-2.70-4a1b877-win64
Backface culling is disabled and double sided enabled however you cannot see the faces in edit mode or object mode.
Normals appear on these invisible faces though.
Switch to Cycles rendered mode and you will see some faces covering the window.
(see attached file)
invisible_faces.blend
Added subscriber: @dragostanasie
Added subscriber: @willi-2
You've created several concave ngons here. I suggest: go to edit mode, select all and press Ctrl+T (triangulate). Now you see what's actually wrong. So I suggest you clean-up the mesh first, then try again. You have some double edges, too.
The problem I see with Blender is only that concave ngons in solid shading mode in the view port are not displayed as when rendered, however this can be a known limitation (let's see what a dev says about it).
For example:
invisible_faces_new.blend
Only use the mesh. UVmap has to be recreated.
I have a better example, minimal. This just renders badly. There seems to be a problem with the ngons.
These objects have been imported and not created by hand.
faces_bug.blend
I do not see a problem with this file.
Object mode:
Edit mode:
Rendered:
Note, I'm using CPU rendering.
GPU rendering fails in the Viewport, CPU works fine here.
Switching to "Static BVH" type fixes it for GPU.
There's two different problems here. The first one is because of problematic ngons.
The other is because of float precision issues, due to the polygon being quite far from the origin, which gets worse due to imprecision of instancing. We'd like to improve precision here but this is not considered a bug at the moment.
