SSS in BI strange "shadow" #40302
Reference: blender/blender#40302
Windows 7 professional 64bit
NVIDIA Geforce 560Ti
Broken: Blender 2.70a (been broken for a while I guess)
If two objects with SSS material occlude each other, the foremost object gets a "shadow" from the object that is behind.
See attached images, and the .blend-file.
Make two objects with a material with a clearly visible SSS.
Put them so, that from the camera's point of view, one is partially behind the other.
They should be lit from behind ie. backlit. (However, the SSS "shadow" is not caused by the second object casting a shadow..)
Example .blend provided.
SSS_bug.blend
Added subscriber: @SakariLeppa
Added subscriber: @totoro-4
At the first pass (to render the hidden faces I think?) it puts the front object behind the other.
Added subscriber: @brecht
@brecht, mind having a look? :)
Added subscriber: @Sergey
It's a limitation of the rasterization based SSS method in Blender, it distributes SSS samples on the first and last faces in each pixel, but not on the faces between.
A more advanced SSS method could be implemented, but at the moment this is not considered a bug.
A possible workaround then to render the two objects separately into render layers and merge them with the node editor.
