Boolean modifier with Freestyle edges #40315
Reference: blender/blender#40315
Ubuntu 14.04 64bit NVidia 440
Broken: 2.70
c56bbcc
Boolean modifier keeps only the Freestyle edges of the original mesh (not like the Sharp/Seam edges, they are merged with the masking mesh). If you apply the modifier, all Freestyle edge attributes are lost.
Create two mesh objects. Set boolean modifier for one of them using the other. Set some Freestyle edges for both of them in Edit mode. Disable the masking layer for rendering so you can see only the modifier's output. Render it with Freestyle enabled. You can see only the original mesh's Freestyle edges are there. Apply the modifier. Render again. No Freestyle edges at all.
bool_edge_mark.blend
Added subscriber: @totoro-4
Added subscriber: @kjym3
Just FYI, Campbell recently addressed a similar problem with the subsurf modifier in the commit
3182c54da6
.The exporter_SetEdge() in MOD_boolean_util.c copies the edge customdata. It seems for me (but not sure, I apologize for the things below if I'm wrong) that CARVE_MESH_LEFT means the original object and CARVE_MESH_RIGHT is the masking object. But I don't know what CustomData_copy_data() copies here. Maybe this supposed to copy the edge customdata from the CARVE_MESH_RIGHT object? Because the CARVE_MESH_LEFT object's data comes from somewhere else. If I comment out this copy instruction the freestyle edges are still there (before applying of course).
I think 'orig_edge_index' has a meaning only together with 'which_orig_mesh' here.
But even this copied data won't be in the final result if the applyModifier() gets the MOD_APPLY_USECACHE flag in MOD_boolean.c.
This issue was referenced by
3b4f792ce1
Closed by commit
3b4f792ce1
.Added subscriber: @Sergey
@Sergey thank you! But something still missing. Now the edges are there from both objects AFTER applying the modifier, but through the modifier the edges from the masking object are still missing. Render my original example scene before and after apply to see the difference.
I don't know if it helps, but I've made some debugging with this MOD_boolean_util.c. The output DerivedMesh always contains the good freestyle edge customdata layer, but later (I don't know where) something overwrites this information. This happening after the modifier, and it rebuilds the freestyle edge layer (and perhaps others too) using the contents of the CD_ORIGINDEX layer as an index to the original mesh's edges. The exporter_SetEdge() function fills the contents of this index layer but it refers only to the original mesh (left) and not to the masking mesh (right).
Changed status from 'Resolved' to: 'Open'
Hi @Sergey,
Thank to the commit, now applying the modifier gives a correct boolean result with all Freestyle edge marks kept. Still only edge marks of the modified object (left object) are kept when rendering without applying the modifier, and those edge marks from the modifier parameter object (right object) are lost.
I think this is a design bug in the modifier system. The
3182c54da6
bug was the same thing. Now the modifiers must serve two different workflows at once. For applying it creates the customdata by itself, but without applying it passes a list about the edges mapping (and perhaps faces etc.). I think the modifier knows better what is what, so this postprocessing is not a good idea. It restricts design of future modifiers too. Was this originally a speedup to not copy all the data during the modifier chain but only reference?@kjym3, afraid that's up to you, not me ;)
Seems that the issue is inside
make_freestyle_edge_mark_hash()
which for some reason uses CD layer from original mesh, not DM. Hence it'll fail to get flags for edges which doesn't ORIGINDEX.Here's a patch which makes it so flags from DM are used, but not sure maybe it was a reason to use flags from the base mesh (which i don't actually see): http://www.pasteall.org/51902/diff
I'm happy to hear it is not a general problem in Blender. Actually I didn't check the freestyle part... Thank you @Sergey!
Thank you Sergey for the fix for make_freestyle_edge_mark_hash(). I found a related issue that edge marks from the parameter object of the boolean modifier were still missing when the object has modifiers in its own modifier stack. Please, consider a code review of D558 which includes fixes of the two issues.
Hello @kjym3, thank you! I hope this finishes this bug. I cannot try it yet, the code review is not in the git. As a notice, I see a very similar part in convertblender.c at lines 3327 and 3366 for the CD_FREESTYLE_FACE marks, using the CD_ORIGINDEX again. Maybe it also needs a correction?
Yes, the CD_FREESTYLE_FACE stuff also requires a code revision. Patch D558 focuses on edge marks. I will address the face marks issue separately.
edfd989e86
Closed by commit
edfd989e86
