Offset doesn't turn purple when driver added #40350
7 Participants
Reference: blender/blender#40350
Win 7 64bit
Broken: 2.7a (including recent builds)
Worked: none?
Problem
Import a plane, assign an image sequence to it as a texture, right-click the Offset field, Add Driver. The Offset field doesn't change color to indicate a driver has been added. I assume this is a bug.
Added subscriber: @MattVG-4
Added subscriber: @totoro-4
Also the "Add driver" option remains in the menu instead of "Remove driver". But it seems the driver is there and produces truncated (rounded towards zero) integers.
Added subscriber: @mont29
I can’t confirm this, please test with latest builds from the buildbot, and attach a simple .blend file to reproduce the issue.
Only thing I do can confirm is that the default interpolation of drivers curves is elastic, which is bad (will fix)!
Actually, can’t reproduce that with latest master either…
Added subscriber: @willi-2
Can confirm this on Win7/64, blender-2.70-7fb33e5-win64:
Arg, we did not talk about the same offset setting (I thought it was mapping offset stuff)! Another illustration of importance of joining a demo .blend file!
Hrrm… on this prop, driver is created in Object's animation_data, while simple fcurves are on Texture one. That’s stupid, one way or the other!
Added subscriber: @JoshuaLeung
Ok, so culprit is
get_driver_path_hack()
, which produces ugly complex paths rooted to Object ID for materials' textures, likematerial_slots["Material"].material.texture_slots["Tex"].texture.image_user.frame_offset
, instead of nice simpleimage_user.frame_offset
rooted on texture ID, like anywhere else.This is done for (again!) depsgraph reasons it seems (though a comment in code suggests it might not be needed anymore). So we either remove this hack, or we tweak
rna_get_fcurve()
to handle that hack correctly (right now, it’s code simply can’t find drivers with that kind of path).Joshua, what do you think?
PS: latest option (tweaking
rna_get_fcurve()
) is probably the only one valid at this stage of release process, removing the hack we do not really have time to test seriously, can backfire easily.IMO, this is not something very urgent or high priority, and definitely not something new, and not really something I'd consider as a candidate for fixing for the upcoming release (given the current stage in the release cycle).
BTW:
About 2, no, my default is Bezier, but I could never reproduce that, so probably did a wrong manip before I noticed it the first time, definitively not a bug.
About 1, I suspected something like that. Will just update
rna_get_fcurve()
to handle such situation then (having visual feedback of driven props is rather important, imho).The driver is working, even it is updating the gui button, so this is not a functional bug. I think the path is working from the driver to the button, but not backwards, right? Why not the driver sets the button state when it updates its displayed value?
Added subscribers: @brecht, @ideasman42
Here is a patch that fixes UI (not
RNA_property_animated()
, though, since there is no context available here :( ):P68: #40350
Unfortunately, it makes things even more hacky… brecht, campbell, what do you think, can we accept that driven texture properties do not appear as such in the UI? Or can we accept to add more hackish code here?
Regarding the initial bug:
I apologize for not being clear. I was rushed when I was reporting. Here's a screenshot from Blender 2.71 testbuild 1. Blender Internal. I used the Import Image as Plane addon if that makes a difference.
Screenshot
IMHO this should be postponed until after 2.71 release.
New patch after talk with Campbell:
P152: Fork of P68 #40350
This issue was referenced by
8cb1b35bee
Closed by commit
8cb1b35bee
