Texture images are not properly displayed in the material preview in BI when using SSS #40364
5 Participants
Reference: blender/blender#40364
i7 720QM 1.6GHz, Windows 7 Pro 64bit w/SP1, 8GB RAM, Nvidia GeForce GTS 360M w/1GB VRAM
Broken: 2.70a (Hash:
f93bc76
) 64bit (blender-2.70a-windows64.zip)Broken: 2.71 testbuild1 (Hash:
c56bbcc
) 64bit (blender-2.71-testbuild1-win64.zip)Worked: 2.69.0 64bit (r60995)
In the above 2.71 testbuild as well as in the 2.70a revision I noticed that if a material in Blender Internal has an image texture applied and mapped to it, as soon as you activate the Subsurface Scattering option in the Material properties panel the texture is no longer visible in the material preview window if the SSS Blend for Textures is set to value 0, and becomes visible the more you raise this value becoming fully visible at Blend Texture value of 1. The image texture is instead displayed correctly in Blender version 2.69.
I don't know if this was an intentional design change or if it's a bug but surely it doesn't help to evaluate the SSS effect correctly unless you render the object. Please, let me know if I misunderstood the BI SSS behaviour or else. Thanks.
Open Blender and set it to Blender Internal render, with the default scene and the default material assigned to the cube go to the material's textures panel, change the texture type to Image or Movie and assign any image to the cube (you can set texture Mapping to Generated, Cube Projection). Then, go back to the Material tab and tick the SSS option; with the Blend Texture at value 0 the image texture previously visible in the material preview box is now gone and the material displays only the base diffuse color. If you raise the Blend Texture value the mapped image start becoming visible until you reach value of 1 where it's fully displayed in the preview.
Added subscriber: @Harvester
Added subscriber: @LukasTonne
SSS generally doesn't seem to work in BI previews any longer. Whether this is a deliberate change or a bug i can't say. It's a bit difficult to see in 2.69 previews, but you can increase the sss scale and in 2.70 you can increase the preview size as well, so it becomes quite clear there is no sss happening at all in 2.70.
Test file: test_03.blend
Hi Lukas, so it's confirmed SSS doesn't work in BI previews any longer also with the latest 2.71 version, but since the 3D Viewport Shading "Rendered" works fine in displaying the SSS effect in BI, there is a way to preview it in realtime on materials.
I will look forward for this problem to be eventually corrected in the future and thank you.
Was thinking another day, why not look into this report :)
This issue was referenced by
7587e82c28
Closed by commit
7587e82c28
.Great job Sergey! I sincerely thank you.
