Automatically generate blender.1 man page during build process #40418
2 Participants
Reference: blender/blender#40418
The
blender.1
manpage is automatically generated by the scriptblender.1.py
by postprocessing the output from the--help
and--version
commands from the Blender executable. Having such automatically-generated output in the source tree means that any changes to the relevant help text require a separate manual step to update this file.This patch gets rid of the
blender.1
file from the source tree, and adds CMake commands to automatically generate it at build time. This saves the separate manual steps for keeping it up to date.autogen-manpage.patch
Added subscriber: @ldo
In general I think this is OK, but things to consider.
Also looks like
is reversed?Oops, yes, patch looks reversed.
Python binary needed: surely any reasonable system would have that. :)
Thinking about cross-compiling: good point. Perhaps the answer is to move that help text into a separate file, and have it included from there into the Blender code and man page at build time.
Just thought i should point this out, in the current source tree, blender.1.py is not marked as executable. My Git patch marks it as executable (note the “old mode” and “new mode” lines); don’t know if that would automatically happen if you were to apply the patch.
Moving the help text to a separate file would make it easier to generate the man page directly from CMake without needing Python, similar to the way my makesdna patch #37228 generates
dna_list.c
.@ldo, the issue with having a separate file is args are documented in
creator.c
via calls toBLI_argsAdd
.Having Python available seems reasonable ... but! - OSX for example doesn't have python3 in the $PATH, windows also.
For Linux now, having some Python3 in the $PATH is reasonable to expect, but when Blender first moved to Python3 this definitely wasn't the case.
Another way to resolve this could be to move the responsibility of making the man page to the packagers.
So for example, dep, rpm, pacman... etc... would have to run the script as apart of installing the package.
Yes, the way the options docs are generated is an issue. The script currently runs with Python2, not Python3.
By the way, the SCons build scripts don’t even install the man page, as far as I can make out. So perhaps its absence in certain cases is not such a calamity. :)
Re your point about Python3: was the script meant to be invoked as “python3 blender.1.py ...” rather than “blender.1.py ...”? Seems to run OK with Python2. :)
@ldo, right, this is mostly for linux packages which expect a man page. (and most/all currently use cmake).
doc/manpage/blender.1.py
- runs with python2.6+ & 3.In this case its no problem to support both, but in general we may want to depend on an exact python version for some scripts.
Just stuff to keep in mind, in this case its not really a problem.
I don’t think Linux packaging uses cross-platform builds. I believe Debian doesn’t support this.
Also it seems to me Blender cannot be cross-compiled anyway, since the makesdna and makesrna executables need to run as part of the build process. I don’t see anything to build them with different platform flags from the Blender executable itself.
Here’s a resubmitted patch, the right way round this time. :)
Mostly LGTM, noticed some issues.
man_format
as is, function allows for easier extending if needed.flush()
before closing, closing implies flush."
at the end.regarding cross compiling, we had this working for linux, windows at one point, but needed to run makesdna through wine. But this isnt supported anymore.
OK, changes made as requested. But I can’t see anywhere that a leftover quotation mark appears.
autogen-manpage-20140531.patch
Attached a cleaned up patch: autogen-manpage-20140531.diff
The extra
I'm getting because I build with color management disabled.So I get the message
Committed
cb7915fc60
thanks for working on this issue (was silly to manually regenerate).
