Switching object in EditMode to invisible layer locks you out of ObjectMode #40526
5 Participants
Reference: blender/blender#40526
Debian Linux with Radeon HD 7470 graphics card
Broken:2.70a
If an object being editted is moved to a non-visible layer, the UI can no longer be switched from Edit Mode to Object Mode
Take any .blend scene, even the initial cube.
Press 1 so only Layer 1 is visible
Select the cube object and TAB into Edit Mode.
In the Properties window select the Object Tab.
Within the Relations->Layers, switch the object to Layer 2, which is not visible.
You are now locked out of switching to Object Mode, either by pressing TAB or via the 2D view's object interaction pulldown.
To fix this, you must either switch the object BACK to a visible layer, or press a number key to make the object's layer visible.
Added subscriber: @cmuAdamson
#40700 was marked as duplicate of this issue
Added subscriber: @kevindietrich
Can confirm this behavior on Linux with latest head as well (
918f6a4
)Added subscriber: @LukasTonne
Confirmed.
There is a discrepancy in "object from context" functions used in the operators here:
poll
method, however, usesED_object_active_context
. This function retrieves the context.object attribute primarily, which is defined screen-wide without filtering by visible layers.So while the poll method passes, the actual execution function quits early due to the filtering.
Added subscribers: @Sergey, @ideasman42
Discussed with @ideasman42 and @Sergey on IRC. There are a few potential solutions, unfortunately none of them is really feasible:
consistently throughout mode switch operators. This would be the least radical solution, but the standard way of using active object is still via context.active_object. Changing each and every ocurrence is a major undertaking and hard to prevent the same bug in the future this way.active_object
by layers would not happen. Unfortunately this can have unwanted side effects, particularly for things like localview and unlocked layers.context.active_object
in general. This would have even worse side effects, although it might be the correct behavior. There is no telling what would happen in all the hundreds of other use cases ...So for now will put this bug on the ToDo list ...
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Editors#3D_View
Added subscriber: @ReeceRobinson
◀ Merged tasks: #40700.
