two linked 'Child of - constraint' causes object to jump at 180 degree rotation #40671
2 Participants
Reference: blender/blender#40671
Ubuntu 14.04
Broken: 2.71 RC,
169c95b
If at least three objects are linked by two child of constraints, where the second constraint influence is set to 0.5 (not 1) the third object jump after 180 degree rotation
You will see that the third cube jump when the first cube has rotated 180 degrees. The problem is that the second cube orient itself at 180 degrees.
Speculation
The cause of the reason might be how the rotation vector has been defined, that it needs to make 720 degree turn to get back to original position. This might be missed in Child of - constraint.
This is my first bug report. I would like to receive any feedback to learn to report bugs better next time.rotation_bug_report.blend
Added subscriber: @hoseppan
Added subscriber: @JoshuaLeung
This is another one of those intractable issues related to matrix decomposition limitations causing issues when trying to blend between the results of different constraints, not to mention the fact that the childof constraint needs to do some fairly evil space-conversion things which don't really play nicely when applied partially.
Closing as a "won't/can't fix" and noted in wiki.
