Loss file editing curves #40776
Closed
opened 2014-06-23 21:04:49 +02:00 by Ricky J · 5 comments
Win 8.1
video - AMD HD8670 D
all soft are updated
file sample
Pastgal code : http://www.pasteall.org/blend/29980
Blender version
19e627c
and
29e8c46
Loss file after modifying curves!
i did a file were i added some wires using curves with object array and curves
but when i opened up that file i saw that all wire i did has lost their round curve shape
only the curve was left
so i copied and added new wire and deleted old curve
did a render and it work fine then savde file
but when i tried to re open file it refuse to open
i tried to append scene to a new file and it did not work!
win 8.1 error
Fault bucket 85937495187, type 4
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: blender.exe
P2: 2.7.1.0
P3: 539c1328
P4: blender.exe
P5: 2.7.1.0
P6: 539c1328
P7: c0000005
P8: 0000000000849ee4
P9:
P10:
notes:
1-
i was able to append most of the objects in a new file
but as soon as i tried to import several curves at ounce
it crashed
but i was able to import one curve at a time
which is strange!
thanks for any feedback
happy blendering
Win 8.1 video - AMD HD8670 D all soft are updated file sample Pastgal code : http://www.pasteall.org/blend/29980 Blender version 19e627c and 29e8c46 Loss file after modifying curves! i did a file were i added some wires using curves with object array and curves but when i opened up that file i saw that all wire i did has lost their round curve shape only the curve was left so i copied and added new wire and deleted old curve did a render and it work fine then savde file but when i tried to re open file it refuse to open i tried to append scene to a new file and it did not work! win 8.1 error Fault bucket 85937495187, type 4 Event Name: APPCRASH Response: Not available Cab Id: 0 Problem signature: [P1](https://archive.blender.org/developer/P1.txt): blender.exe [P2](https://archive.blender.org/developer/P2.txt): 2.7.1.0 [P3](https://archive.blender.org/developer/P3.txt): 539c1328 [P4](https://archive.blender.org/developer/P4.txt): blender.exe [P5](https://archive.blender.org/developer/P5.txt): 2.7.1.0 [P6](https://archive.blender.org/developer/P6.txt): 539c1328 [P7](https://archive.blender.org/developer/P7.txt): c0000005 P8: 0000000000849ee4 [P9](https://archive.blender.org/developer/P9.txt): [P10](https://archive.blender.org/developer/P10.txt): notes: 1- i was able to append most of the objects in a new file but as soon as i tried to import several curves at ounce it crashed but i was able to import one curve at a time which is strange! thanks for any feedback happy blendering
Author
Author
Added subscriber: @rickyblender
Sergey Sharybin self-assigned this 2014-06-25 12:04:22 +02:00
This issue was referenced by deb3999696
This issue was referenced by deb3999696cbcbe19ace96f334477a985e835060
Closed by commit deb3999696.
Reference: blender/blender#40776
