Sound strip crash in Video Sequence Editor #40786
Closed
opened 2014-06-24 14:25:31 +02:00 by Georg K · 5 comments
win7 SP1 and ubuntu 14.04, Radeon HD7770
Broken: Blender 2.70a official and recent own build Hash: 7280410
Worked: ?
Trying to play a Sound strip that has been extended at the start (negative start trim) makes Blender crash
  • in the VSE, Add Sound (align start to frame 1)
  • in the properties of the strip, enable Cashing
  • set Trim Duration (soft) to a negative value for "Start:"
  • press Shift-Leftarrow and Blender crashes
or set current frame to 0 by RMB-clicking in VSE or timeline and Blender crashes
This not perfectly reproducible: wav, mp3, aif and flac files all crashed but unfortunately not every time even with the same file.
The crash does not occur if the soundfile is packed (might be a coincidence) so you have to create it yourself by loading a sound in the VSE:
Please download this mp3 http://dig.ccmixter.org/files/basematic/33579 or try some of your own files.
blender.crash.txt:
Blender 2.70 (sub 0), Commit date: 2014-04-10 11:49, Hash f93bc76
bpy.context.area.type = 'VIEW_3D' # Property
bpy.data.sounds["basematic_-Orc_March.mp3"].use_memory_cache = True # Property
bpy.context.scene.sequence_editor.sequences_all["basematic
-_Orc_March.mp3"].frame_offset_start = -1 # Property
**System Information** win7 SP1 and ubuntu 14.04, Radeon HD7770 **Blender Version** Broken: Blender 2.70a official and recent own build Hash: 7280410 Worked: ? **Short description of error** Trying to play a Sound strip that has been extended at the start (negative start trim) makes Blender crash **Exact steps for others to reproduce the error** - in the VSE, Add Sound (align start to frame 1) - in the properties of the strip, enable Cashing - set Trim Duration (soft) to a negative value for "Start:" - press Shift-Leftarrow and Blender crashes ``` or set current frame to 0 by RMB-clicking in VSE or timeline and Blender crashes ``` This not perfectly reproducible: wav, mp3, aif and flac files all crashed but unfortunately not every time even with the same file. The crash does not occur if the soundfile is packed (might be a coincidence) so you have to create it yourself by loading a sound in the VSE: Please download this mp3 http://dig.ccmixter.org/files/basematic/33579 or try some of your own files. blender.crash.txt: # Blender 2.70 (sub 0), Commit date: 2014-04-10 11:49, Hash f93bc76 bpy.context.area.type = 'VIEW_3D' # Property bpy.data.sounds["basematic_-_Orc_March.mp3"].use_memory_cache = True # Property bpy.context.scene.sequence_editor.sequences_all["basematic_-_Orc_March.mp3"].frame_offset_start = -1 # Property
Author
Author
Added subscriber: @georgK
This issue was referenced by 72f77dd69a
This issue was referenced by 72f77dd69afc929fcde20ffc1dc66b5149c01b1f
Closed by commit 72f77dd69a.
Reference: blender/blender#40786
