Cycles is not rendering direct light with volumetrics, only indirect (builds from buildbot after 2.71). 2.71 renders are ok) #40987
Reference: blender/blender#40987
Lenovo Y580 Intel Core i7-3630QM CPU, 15,6 GiB RAM, Nvidia GeForce GTX 660M (GK107M), Linux Mint 17 64-bit
Broken: Blender 2.71 from buildbot (Hash
4299b00
) (and several earlier versions)Worked: Blender 2.71 stable (Hash:
9337574
)Short description of error
Cycles is not rendering direct light with volumetrics, only indirect.
Just starting with the default cube, add to it Object/quick effects/quick smoke, Add a volume scatter shader to created domain, with attribute node with density parameter as density of the shader, Simulate several frames, F12 for render.
Added subscriber: @Rogo
Sorry for that, Didnt know how to edit previous posts. Adding some files according to this bug.
Thank You!
untitled2.blend
Added subscriber: @Ace_Dragon
You might want to simplify this a little.
Instead of using a smoke object, just add a volumetric material to the cube so verify as to whether or not the issue might be specific to smoke rendering.
Also, if the lamp size is small, you might have trouble getting any sort of lighting on it even if using MIS, though regressions in terms of direct lighting abilities are always possible.
Thank you ace_dragon.
Yes, simplified scene reproduces same bug. Just connect a volume scatter shader to default cube (default scene), removing diffuse one. No direct light. Lamp size makes no difference.
Blender 2.71 render is all fine, later versions are not.
"No direct light" I mean "no direct light" noticeable still in render.
Sorry for flooding.
Sun Lamps are not supported, as they are infinitely far away.
In the post 2.71 builds, Volume Bounces default to 0, set it to 1, then it should look like the 2.71 release.
@ThomasDinges This is bug due to any type of light in this case. I dont use sun lamps. World has no volumetrics. Please download my .blend file and test it. Volume Bounces settings make no differences.
I downloaded untitled2.blend and there is a Sun Lamp in it. Switch to Point Lamp, increase strength it works fine!
Ok. I changed light to point and increased its strenhgt. Its working. Still I dont understand why sun does not work with volumes like such domain. I understand why it doesnt work with world volume (pretty reasonable -light at infinite distance and volumetric world) but why doesnt it work here? Volume domain has its thickness, and it should be considered in all calculations. Why is the sunlight in this case???
BTW @ThomasDinges, You are doing such a great job on Cycles!
You can see for yourself if you 'build' the sun into the environmental light and make it a really small source.
Cycles is a unidirectional pathtracer and that combined with a volume means it will be very hard to illuminate the surface with a source that small.
It's kind of unfortunate really because it means we still have to use stacked cards, the motion blur workaround, or the old internal engine if we want real volumetric cloud and smoke effects in outdoor scenes without tricky compositing tricks, and I'm not sure if there's any papers covering the topic of successfully lighting a cloud from a distant source without a sort of shading cache.
Actually this is a bug, and was introduced after the 2.71 release, working on a fix atm: D639
The issue has been fixed now: https://developer.blender.org/rBe35845d37cd9ff9ab287eb8250476de687cca832
