Crash on undo or deleting an armature #40998
2 Participants
Reference: blender/blender#40998
windows 8.1 x64, geforce 660
Broken: since 2.70
Worked: 2.69
in the armature in the attached file, try to delete it, or move in pose mode and undo, it will crash.
compiled using scons and mingw, also tested msvc2013
the file:
ep1_err.blend
Added subscriber: @bat3a
Added subscriber: @Sergey
This is actually a corrupted file. It worked before because of some specifics of old memory allocator we used. The same behavior you'll have running blender with --debug-memory command line argument.
But the root of the issue comes to the fact that your object has an unknown type of constraint. You can see it by running this in the python console: C.object.constraints[0]
In order to fix the issue we need to know how exactly to reproduce such a situation from scratch.
it's a simple armature with ik constraint nothing more, made in 2.5x series, and there are no error in 2.69 and works as expected, if the file is corrupt i imported the rig in an new file, and had the same error after v.2.69, does this help?
is there anything i can help with?
thank you.
No, it does not help. As said -- we need to know how to reproduce such a corrupted file from a file which is NOT corrupted. We can't do anything about this file really.
Blender 2.69 worked because it used different memory allocator, which is now available if you use
--debug-memory
command line argument. Blender 2.69 just silently ignored the whole bunch of errors in this case, you can see all of them if you open the console. This was changed in order to make memory allocator much more friendly for threading (as a part of threaded depsgraph project).So in order to solve the actual issue we need to fix a bug which allowed you to corrupt constraints stack, but for this we really do need to know how to produce such situation from scratch (or at least non-corrupted file).
so importing the old file in a new file doesn't solve the corruption, then do you recommend anything to rescue my file?
thank you.
Go to 2.69, add a new armature with single bone, go object data buttons, change armature datablock from Armature to afkar.Arm.001, delete old armature, save. File should work fine in new blender as well.
You would probably want to copy-paste pose as well.
This is all rather workaround, as said -- real fix could only be done when we know for sure how to produce such a file. For until then i'm gonna to archive the report.
that worked.
thanks
