Warped UV Layout #41078
Reference: blender/blender#41078
OS: Windows 7 Home Premium, SP 1
Graphics Card: AMD Radeon HD 6320
Broken: 2.70, Hash:
19e627c
Worked: Haven't tested.
While in Cycles, I used the "Project from view" UV unwrap option. After resizing the UV image, the layout got squished. I tried project fomr view again to fix it, but it stayed warped until I switched to the internal renderer and used the option, it went back to normal.
To reproduce: While in cycles, use project from view on an object, then resize the default UV image horizontally or vertically. The wires should get squished. Try projecting it again in, still in cycles. It won't fix the squishing, but if you re-project it in BI it will fix the problem.
boeing-747-400.blend
Added subscriber: @Terrance8d
Added subscriber: @mont29
Added subscriber: @TomaszJurczyk
If you have no texture node connected to shader in node editor blender assumes that there is square texture. No matter what is opened in image editor. So if you have image with other than 1:1 proportion rectangle, projection is squashed.
You can fix it by plugging this image as a texture to some input in node editor, but still it is a bug. I would like to projection work in cycles in the same way like in internal with proportion of opened in UV editor texture instead of plugged texture node.
by "proportion" I meant Aspect Ratio of image.Please forgive my English.
another thing is that if you don't have this texture node connected in cycles material UV -> show other object does not work
This is by design. It's is confusing and may get improved at some point, but currently the image shown in the image editor is decoupled from the one assigned in the material.
http://wiki.blender.org/index.php/Doc:2.6/Manual/Render/Cycles/Texture_Editing
