VSE: cropping strips puts a transparent line through the image #41241
Closed
opened 2014-07-30 01:17:12 +02:00 by reade · 6 comments
Win 7 9800GTX+
tested on 2.71 9337574 and 2.65 r53189
Enabling crop on the top or bottom of a strip in the VSE can create a transparent 1-pixel-high line along the bottom edge of the image when the image gets stretched to fit. Extreme cropping will stretch this line wider.
This line shows up in the preview and the final render.
The colors in the image seem to influence the transparency of the line (red apparently less affected than green or blue).
In Video Sequence Editor add a test image or movie and match the render resolution. Enable Image Crop on the strip and increase Top and Bottom values a little. A transparent line should be visible just above the bottom edge.
Here is a prepared test image and file:
test.png vse_crop_test.blend
**System Information** Win 7 9800GTX+ **Blender Version** tested on 2.71 9337574 and 2.65 r53189 **Short description of error** Enabling crop on the top or bottom of a strip in the VSE can create a transparent 1-pixel-high line along the bottom edge of the image when the image gets stretched to fit. Extreme cropping will stretch this line wider. This line shows up in the preview and the final render. The colors in the image seem to influence the transparency of the line (red apparently less affected than green or blue). **Exact steps for others to reproduce the error** In Video Sequence Editor add a test image or movie and match the render resolution. Enable Image Crop on the strip and increase Top and Bottom values a little. A transparent line should be visible just above the bottom edge. Here is a prepared test image and file: ![test.png](https://archive.blender.org/developer/F100229/test.png) [vse_crop_test.blend](https://archive.blender.org/developer/F100230/vse_crop_test.blend)
Author
Author
Added subscriber: @jxqz
Added subscriber: @mont29
Bastien Montagne self-assigned this 2014-07-30 08:17:09 +02:00
This issue was referenced by fa8d38da74
This issue was referenced by fa8d38da74946d3d08ecb4548db98eb2a855b096
Closed by commit fa8d38da74.
Reference: blender/blender#41241
