M-node crash #41349
7 Participants
Reference: blender/blender#41349
windows7 64
ASUS ATI Radeon HD6870
Broken: 2.71 (
9337574
)Worked: (i don't know, i was see it yesterday)
Blender closeing, when i use a node textures, press M button to mute and try to render
1.Create any texture
2.Go to Node editor, use a node for this texture, create anything(what type of node - is not important)
3.select any,press M to mute
4.Try to render or go to rendered shadng mode(Blender close)
Added subscriber: @Inwader77
Added subscriber: @kevindietrich
Please try with a nightly build and upload a file that fails for you if the bug still occurs, things might have change since the 2.71 release. Also is it Cycles or Blender Internal ?
This comment was removed by @Inwader77
M-_node_bug_official_release.blend
This bug in Blender internal(i do not use a cycles and i do not know how use a node for textures in cycles)
To activate bug 2 methods:
1)open this file and press F12 to render(blender crush(close))
2)go to tex paint mode and paint anything with this texture(blender crush(close))
If i create any tex,use node and mute, but do not use this texture nowhere - working normal
if i use this tex for world, material, or lamp and try to render - blender close
if i use this texture for paint and try to paint anything - blender close
if i use this texture only for paint(and nowhere else) and render - working normal
I try to do this in night build (
81c3fc9
) - working with bug.in blender 2.63(r45996) - not close,but ignore mute function in render and paint
P.S.1)Sometimes blender can crush, if i (for example) use this texture for world ang do to properties/world data/prewiew.
2)Sometimes(very seldom) blender do not close, but render and ignore mute function, and if i try to render again - close
When hitting render, I'm getting:
and when trying to paint:
In both cases the backtrace looks like this: http://www.pasteall.org/53335/text. This is just an except as it is indefinitely repeating.
I don't understand what i must do to work normal. I don't know what this code mean.
And else, try to use mute for material nodes - don't crush, but ignore mute function.
Use for scene node - working normal.
And else:
texture node:
2,62(r44136) and earlier - working without bug.
2.63 - 2.70 - no crush, but ignore mute
2.71 - crush
material node:
2.62(r44136)and earlier - working without bug.
2.63 - 2.71 - ignore mute function.
For material nodes:
in viewer, output node and in preview(property window/material settings context menu) - working normal, but in 3d view and in render - bug is active
This bug is active for BI and Cycles.
In 3d view(select GLSL mode(not multtex)) with textured shading mode - working properly, with rendered mode - bug is active
versions 2.71.3(
ee8dafe
) and(3d4f540) - working with errorAdded subscriber: @mont29
Added subscribers: @LukasTonne, @Sergey
I'm having stack overflow issues actually.
@LukasTonne, seems disabling mute for texture nodes makes things stable here. I know it's an old can of worms, so maybe for now just disable mute functionality there if you're not sure how to fix it properly?
Closed by commit
1743c81ce1
.This issue was referenced by
1743c81ce1
Added subscriber: @Psy-Fi
Hey, I found something that works without disabling muting here, can @LukasTonne or @Sergey check? exec_muted_tex.patch
This should also take care of #41761 too.
59a38ccc42
Only in
8c3daab
muting textures working normal, but muting material - ignore mute function
