Blender 2.71 1) UV projections are distorted. 2) view >>> Draw other objects (in UV/image editor) does not work as well #41370
Reference: blender/blender#41370
Windows 8 64 bit, core i3-540, both intel integrated graphic card and nvidia nvs 440.
Broken: 2.71
Worked: 2.68
Take standard cube, change its dimensions to 1:1:0.075, object mode, apply scale, edit mode, smart UV project, and it is distorted, that is the 2 big faces are not squares, they are rectangles. At least when texture size is 1024*512.
I unwrap one cube, go to object mode, select the cube I already unwrapped and shift select new cube to unwrap on the same image, go edit mode, hit unwrap, go to view >>> draw other objects and outlines of the first unwrapped cube do not show up.
All above bugs do not appear in Blender 2.68 version
2.71_bugs.blend
Added subscriber: @Denis-3
Added subscriber: @mont29
Point 1 Not quite sure this is a bug, afaik this unwrap script does not ensure proportions are kept? Campbell should know…
Point 2 no bug here, since your two objects have same unwrap… just move active one, you’ll see the other is there.
Yes mont29 you are right, second issue is not a bug as it turns out, but I clearly remember working on another project and it did not show up, I was moving UV around, but it seems I cannot recreate that now, anyways thanks for pointing out.
As for the first point, it does ensure proportions are kept at least in blender 2.68.
Just figured out, that problem #1 does not work correctly in cycles, when you switch to blender internal, it does not have distrotion issue!
