Emit map bug #41433
Reference: blender/blender#41433
windows7 64
ASUS ATI Radeon HD6870
Broken: (all)
Worked: (none)
Create a plane(with use a volumetric objects - working prorerly), go to world panel in property window switch on indirrect lighting, select approximate, select plane again and create a emit material with emit map. Emit map( it is ver important) we must open in disk(don't create in blender), switch off use alfa, set emit, try to render - we will see emit, but don't see indirect lighting
if we create a image in blender and use as emit map - workind OK
If we use a volumetric objects like this{F103005}
we will have another error:
indirect is present, but incorrect, and only if we create a two materials:1st - emit 2nd - not emit - glowing properly
1)poen this{F103013}
and try to render (glowing is present)
2)switch off created in blender texture and switch on opened in local disc, render - indirect lighting(glow) is absent
3)open this emit_bug.blend
render, look on result
Added subscriber: @Inwader77
Removed subscriber: @Inwader77
This is the same your previous report -- we can't make algorithm fast and approximate and accurate at the same time. Accurate algorithm is called "Raytrace". This is also mentioned in the tooltip of this settings.
Thanks for the report, but it's just a limitation of approximated approach.
If i use a Raytrace algorithm - i don't see glow(indirect)
Do you mind reporting it as a separate issue with .blend file? So it's not getting lost
I will create a new report, but look on this
I was create new report, but it was closed this task as "Invalid".#41441
