Ramp bug #41582
Reference: blender/blender#41582
windows7 64
ASUS ATI Radeon HD6870
Broken: (All)
Worked: (None)
Create a uv map, material, texture with this image.
switch on ramp mode and switch off use alfa
select rendered shading mode
go to tex paint mode and try to paint anything(use B/W)
and we will see this mode working incorrect.
type of texture - not important
save image - not inportant.
load image or create in blender - not important
use RGB to intencity - is not important
but if we use textures with alfa and activate ramp mode - working normal
working properly with all types of textures (not only image or movie).all textures, with alfa
1){F106723}open this,try to render or select rendered shading mode.(we will not see ramp(gradient in result))
2){F106724}open this,try to render or select rendered shading mode.(and we will see properly working of gragient)
3){F106725}open this,try to render or select rendered shading mode.(and we will see properly working of gragient)
Added subscriber: @Inwader77
Added subscriber: @ideasman42
This report needs to be much more detailed, I tried all 3 files and am not really sure how to redo a bug.
alfa_gradient.blend
for example, has a black overlay texture, with Influence DIffuse Color set to1.0
.Not sure what behavior is expected, based on info from the report.
Influence level is not important. influence level must be activate and not equal 0.
we can use this texture for other influence(specular,bump, emit and others), but difuse is most demonstrably
open first file (ramp bug.blend) - working with bug.(in this file used RGB texture without alfa)
two others files(alfa_gradient.blend and procedurian tex ramp.blend) - working properly(because use alfa)
All this files use diffuse col influence set to 1
Regarding
ramp bug.blend
, The color-band is ignoring the color and only using the alpha from the image texture, if you enableImage Sampling -> Alpha: -> Calculate
, you can get the same effect.This is not an area I'm especially familiar with, but it looks like its working as intended.
Yes, i enabled calculate alfa - i get this effect, but i'm not sure is this properly.
This is actually how things are expected to be working by the design, which kind of actually makes sense -- it just alpha-overlays the image over the gradient.
Wouldn't consider this a bug.
