Skin modifier dont work with 0 face objects #41677
5 Participants
Reference: blender/blender#41677
Windows 7 64, HD 5770
Broken:
9337574
(2.71 release) +35bc266
Objects with Skin modifier dont show up in Game Engine if its geometry have 0 (zero) faces.
SkinBugGE.blend
Add a Plane.
Give it a Skin modifier.
Plane Editmode: Delete one vertice to get kind of a tube.
Added subscriber: @karja
This comment was removed by @karja
Added subscriber: @Ace_Dragon
I'm pretty sure the BGE was never able to render objects without faces unless you assigned a wireframe shader to it.
The mesh doesn't have a surface to begin with, and most surface shaders are designed to work with faces, so no surface means nothing solid to render. You'd get the same using BI and Cycles.
Not sure what you mean, Skin works just fine in BI and Cycles.
The problem is indeed that GE searches a face to display the skinned mesh.
A workaround for example is to add one face, and then hide it with mask modifier, before other operations follow.
Campbell says Skin generally works best with loose edges - you can test this by yourself very easily with a monkey mesh + Skin modifier.
So I still hope this is an issue that can be solved by code.
Added subscribers: @brita, @Moguri, @Sergey
@Moguri, @brita, can you look into this report please?
Added subscriber: @panzergame
I really don't understand this bug report : Why apply a skin modifier on an empty object ?
With 0 face object I mean a mesh without faces, not an empty.
You can use it for low poly meshes or stylized geometry (bone meshes, water waves)
or for (roots of) a tree, for example. Simply what you want.
This comment was removed by @panzergame
Added subscriber: @Blendify
This task is being closed because the BGE has been removed in Blender 2.8.
