Blender crashes trying to load character file #41703
Reference: blender/blender#41703
Fedora 20 GNU/Linux 64 bit on Intel CPU / Nvidia GPU
Broken: git master hash
f7062ff
Worked: 2.71 release from b.o.
Open a specific file (gilgamesh.blend) crashes on file load (almost all the time) with the following in terminal:
the crash.txt is here:gilgameshpacked.crash.txt
It might crash if your setup reproduces mine....
Added subscriber: @BassamKurdali
Added subscribers: @Sergey, @LukasTonne, @mont29
Confirmed, looks like a threading issue in particle code, from quick look to asan backtrace:
P133: (An Untitled Masterwork)
Thanks Bastien!
@BassamKurdali: temp workaround: launch Blender with
-t 1
option (no multi-threading, things will be a bit slower, but at least it loads!).cool, thanks! will do for now.
Ok, tech dev notes.
Here is exactly what happens: a same curve, used as CurveForceField, is evaluated by several hair systems at the same time (threaded depsgraph), without any protection.
More precisely, in effect.c,
precalculate_effector()
ends being called with effectors using the same curve object in parallel, which crashes when callingBKE_displist_make_curveTypes()
, as one can expects!This very simple patch fixes it, not quite sure it would be considered as correct though… :P
P136: #41703
This is not gonna to work -- it doesn't protect you from cases when effector and object which shares the same curve datablock are handled in separate thread simultaneously. Ideally the cache is to be existing here. Not sure we can add a proper dependency in the graph to make it handled all nicely without hack.
f not, better workaround would be to make sure effectors' dependencies are up to date before doing threading in the
scene_update_objects()
.Ok, so depsgraph does create valid dependencies between particle systems and forcefields.
Issue here is that when curve objects are updated (in
BKE_object_handle_update_ex()
), OB_RECALC_DATA is not set, so for curves, curve_cache is not handled, even if empty.In following patch, it's creation is forced in this update func, when empty, so that
never has to call it later:P137: #41703
As usual, not sure we want to do this, or to do this here, etc. ;)
That's suffers exactly the same issue as the previous fix -- in certain circumstances it's still possible to have threading conflict.
Plus it should not be applied for curve objects in general (the patch simply makes it so any tag for curve update will imply data re-evaluation here, which is screwing up the system even more.
If the dependency between an effector and curve exists, check whether effector depends on both object and object data.
Ok, digging more and more, and understanding less and less… :(
Think core of the issue is that, during first evaluation of brand new DAG (just after file loading), all curve guides objects are tagged as not needing any recalc. I tried to reproduce a somewhat simpler similar situation, with only a few hairs & curve_guides (see file attached below), but with this one curve guides are always tagged to recalc after loading…
depsgraph_curve_field.blend
Note I tried to force curveguides to recalc in several places (including while building DAG, which is not nice I guess), but curveguides always remain with a 0 recalc when DAG is evaluated, which means I think their recalc flags are reset somewhere after DAG construction, but before its evaluation… Tbh, I’m lost at this point…
Found more: what happens is,
flush_update_node()
untag our curve guids as needing recalc, since they are on hidden layers.Do not understand why it still evaluates hair emitters, though, since they are also on hidden layer!
Long story short:
flush_pointcache_reset()
set 'pointcache' objects (like those having a psys etc.) recalc flag toOB_RECALC_DATA
regardless of whether they are on invisible layer or not, which breaks work done previously byflush_update_node()
on this aspect.That small patch (yeah, one more) does fix crash, but as usual I’m not quite sure it is valid - maybe a better solution would be to add a temp 'OB_RECALC_HIDDEN' flag, set by
flush_update_node()
and which would prevent any later code to re-enable those objects' recalc? Very hard to take everything into account here, I feel a bit like fighting in a giant plate of spaghetti!P138: #41703
This issue was referenced by
9c19ad1f79
Closed by commit
9c19ad1f79
.woot! so does this win trickiest bug of 2.72 cycle?
