Dynamic paint dissolve time affects render result #42003
Reference: blender/blender#42003
Archlinux
Broken: 2.72 RC1
Cycles vertex color interpolation is not very smooth with fast dynamic paint dissolve times.
It looks better in solid view.
Added subscriber: @gandalf3
Added subscribers: @LukasTonne, @miikah, @ideasman42, @Sergey
That's not an issue with cycles, it's something with applying the dynamic modifier to the mesh. That said, applying the modifier, then going to the vertex paint mode will give you the same "pixelated" result.
I'm not sure how this is intended to work, @miikah might know.
Also CCing @ideasman42 and @LukasTonne since they are also familiar with vertex color and physics.
It's a Cycles "todo" sort of. Dynamic paint relies on vertex color alpha but Cycles is currently able to only access RGB values of vertex colors.
@miikah, but shouldn't at least paint mode be correct then?
No, Vertex Paint mode doesn't use vertex alpha either and I guess thats why it doesn't even display it in the viewport.
IIRC, dynamic paint was first Blender tool to make use of the alpha component of vertex colors. Only then was support added for Blender Internal as well. Before that there was alpha component but it simply wasn't used for anything. I personally thought Cycles had vertex color alpha implemented already as it would be just matter of connecting the value to a node socket, but apparently not.
Well, ok. Let's consider a TODO then. Thanks for the feedback and report.
Then why does it kindof work with the slower dissolve speed?
@gandalf3 Hmm. I investigated the file a bit more and there are two things happening here:
First of all, your file works okay without dissolve because you have set white initial color for the canvas. That means from the first frame its solid white (1.0 alpha) and adding paint to it will create a mix of colors (without alpha changes) so it looks good in the Cycles render.
The confusing part here is that dissolve also dissolves the initial color. In your file it immediately dissolves canvas back to 0.0 alpha -> render fails. I suppose one could expect it to dissolve back to initial color, but the way it currently works makes most sense IMHO. At least as long as alpha was working correctly... :/
