Eekadoodle prevention causes error in LoopTools addon #42058
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#42058
Ubuntu 12.04.3 LTS (error reproducible on other systems, including Mac)
NVIDIA Corporation G94 [GeForce 9600 GT]
Broken: 2.71a
In the LoopTools addon, there is a short block of code for "eekadoodle prevention". Immediately after this block, a check is performed to see if any (quad) faces have a repeat vertex, in which case that vertex is removed before the faces.new() is called. However, the vertex reordering from the eekadoodle prevention prevents the duplicate vertex check from finding the duplicate vertex in one specific case.
Specifically, if faces- [x] at line 1385 of mesh_looptools.py is of the pattern [a, b, 0, 0], then the eekadoodle prevention rearranges this to be [0, a, b, 0] (not checking for a second 0). The repeat vertex check on line 1391 only looks for vertex #3 == vertex #4, because this is apparently how the quads are constructed (for example from line 859). So the repeat vertex check cannot find the repeat 0 that has been moved, and the script crashes at bm.faces.new() at line 1396.
Solutions:
if sorted(faces- ) != sorted(list(set(faces- ))): # there is a repeat
In the attached .blend file, turn on the LoopTools addon. Select the "curves" object. Click on "Loft" in the LoopTools addon. The error happens for any number of segments, using either linear or cubic interpolation.
looptools_error.blend
Added subscriber: @Animik
Closed as duplicate of #45844
