Motion blur broken with particular setup #42105
Reference: blender/blender#42105
Archlinux
GTX 460 (tested with CPU rendering though)
Broken: 2.72
Worked: 2.69 from blender.org
Motion blur broken with certain object/modifiers. Renders slowly and with huge amounts of noise, and gives an unexpected result.
2.69 works fine. (possibly related to #40017?)
Added subscriber: @gandalf3
Added subscriber: @mont29
Well, can confirm same issue on 2.71 too… Sergey, think this is for you?
This is close to #40616 actually. The thing is -- your object is deform modified and enabled for moblur but it also has constructive modifier on top of deformation and which might change topology. It's not really possible to predict whether topology is gonna to be changed or not, so you'll either end up with cases when you manually need to disable the deform moblur for particular objects (as it is now) or you'll need to force enable it. I think it's safer to keep settings as is and just let artists to disable deform moblur for now. I'll try find some nicer approach here which could cover more cases as a part of #40616.
Thanks for the report, will merge the reports now.
Closed as duplicate of #40616
Changing the topology affects motion blur?
This is confusing me.. I found that later frames in the same file (e.g. frame 87) work just fine with deformation motion blur. Why do only the middle frames act up?
I want deformation motion blur, as without it the twisting doesn't get blurred..
Deformation motion blur needs to know how vertex was moved from one frame to another and it has an assumption that topology doesn't change. If the topology changes, then mapping vertices from previous frame to another one becomes much more complex.
I guess that makes sense. But now I have ask why the topology is changing.. The subsurf modifier isn't animated or anything, so at least the number of vertices should remain the same, right?
No, you've got skin modifier on top of the deformation one. Reshuffle the modifiers so the skin and subsurf goes before the deform one.
Oh right.. Well that's annoying, because putting the skin modifier above the deform modifier will deform the nice even wires that the skin modifier makes..
I guess this really isn't possible at the moment.. Will there be support for interpolated deform modifiers in the future (some way of using the modifier to interpolate surfaces instead of interpolating individual vertices)?
In some optimistic horizon future maybe... I can't really think of how it might work without introducing rather huge amount of slowdown :(
