issue with moving nodes and in UI with custom setup #42117
2 Participants
Reference: blender/blender#42117
win 7 x64
Broken: 2.72
Worked: 2.6x- 2.71
In normal case you can move nodes by LMB, RMB or by press B. In this blend file in my configuration setup, moving nodes is accidential.
Some time it moves by LMB other time RMB and another time at all. In default settings it works fine. Also in panel user preferences tooltips don't work if you are above some function.
open blend file and try to move some of two nodes every time using LMB or RMB.node_issue.blend
Added subscriber: @midan-3
Added subscriber: @mont29
We won’t support custom settings, unless you can prove us there is a real bug with it - not incidental breaking due to random custom settings… So unless you give us a very few changes to do to default settings to reproduce your issue, we can’t do anything. Golden rule of bug report: case must be easily reproducible.
but there is nothing special in my settings, just different colours of UI, some shortcuts and arrangement of panels.In one word - only the look There was no problem in blender 2.71 build 1477- the latest I have that works. I have no idea what causes problem, maybe something happened with startup file with 2.72
There is something special in your settings, since it does happen with factory settings!
But investigating which of your changes creates the issue it’s up to you to do…
I have made a research and it is as follows:
so my settings are not a problem. there is something in startup file itself , because it does not work neither "copy previous settings" in splash screen nor dropping startup file into 3dview window and then saving startup file.
We can’t do much against data corruption, unless you can give us a very precise way to reproduce it. In such case, it’s usually better to just delete local userpref files and start again from scratch…
Anyway, since you manage to to fix the situation, think we can close the report, thanks.
