Numkey "." (dot) not working #42124
10 Participants
Reference: blender/blender#42124
ASUS M4A78T-E / AMD Athlon II x3 425 2.7GHz / Kingston 8GB DDR3 1333MHz / NVIDIA GeForce GTX 550 Ti (2GB) / Windows XP SP2 x64
Broken:
2.72 2014-10-03 13:58 32-bit
2.71 2014-06-25 18:36 32-bit
2.70a 2014-04-10 11:49 32-bit
2.69 r60995 32-bit
Zip files dowloaded - not exe / installed.
I can't use the "." (dot) key in the numpad (numeric pad) in my desktop PC.
The key doesn't seem to be recognized.
Other keys do work.
Does work with other programs.
Open Blender, select any object and try to "View Selected".
Also, open/create any text file and try to type "." (a dot) with the numpad.
Added subscriber: @RicardoRoehe
Added subscriber: @willi-2
Here, with Win7/64, "view selected" works well with NumLock Off as well as On. However, in a text window, it only works if NumLock is on, i.e. it doesn't delete a char with NumLock=Off. Unfortunatelly, the navigation keys (arrow, home, end) on NumPad do not work either.
When you open the settings (Alt+Ctrl+U), on the "Input" tab, if you enter "view selected" in the search textbox, which result do you get? I get this:
(BTW, I hope you're not connected to the Internet with only SP2)
Added subscribers: @MartijnBerger, @ThomasDinges, @Sergey
Are you using QWERTY keyboard layout?
I don't have a keybaord with real numpad by hand now. @ThomasDinges, @MartijnBerger can you test this?
@willi-2
User settings are the same as yours.
It doesn't matter to me if the NumLock is ON or OFF - keys always work.
However, with text block, there is this behavior with NumLock OFF:
(P.S.: there is no SP3 for 64-bit Windows XP. =[ )
@Sergey
Yes, QWERTY.
Curious: the numkey "," (comma) and the combination "Ctrl + ," seems to activate "View Selected". The input of that key (comma) is ok (with texts and as shortcut).
Also, problem does not occur with Linux (Mint 13 x64).
Also, I could not open Blender 64-bit on Windows - I receive a "not a valid Win32 application" message (in console I can only see "Access is denied." after the prompt message is closed).
Windows XP x64 is not supported by the 64 bit builds of blender. They require a full patched vista or newer. and we recommend windows 7 SP1 or newer there
@MartijnBerger
Ok. Thank you.
But, how about the Numpad behavior? Is that related with running a 32-bit version of Blender on a 64-bit system?
Just realized: the "/?°" key (simple press, shift+key and AltGr+key, repectively) - outside from Numpad - is not working as well (no output in a text block).
I can not reproduce the issue with neither 64bit nor 32bit blender on win7 64bit. The thing is -- winxp 64bit is not officially supported, it might have some serious issues with drivers and so. unless you'll manage to reproduce the issue with newer windows or 32bit xp wouldn't consider this is a bug.
Thanks for the report, but for until someone manages to reproduce the issue on a supported platform will keep this one archived.
Ok. Fair enough.
Weird thing is I have used Blender with WinXP64 before, without problems. But now I can't make a single version work here (regarding the dot key). Might be a driver issue indeed.
Thank you, fellas!
Greetings!
Started using Windows 10 Home 64-bit recently and can confirm the exact problems reported here: numpad dot/period and key for "/?°" (Portuguese Brazil ABNT2 keyboard) gives no input inside Blender.
Added subscriber: @FloridaJo
What version of Blender?
2.78c (.msi), 2.79rc2, 2.80.1
3ab46f4
Added subscriber: @dfelinto
@RicardoRoehe I suspect your Brazilian keyboard is sending a comma instead of a period.
In the Logic Editor add a Keyboard sensor, mouse click in the "Key" and press your Numpad dot. What does it show?
Also, if you replace the "View Selected" shortcut in your user preferences to you your NUMPAD dot, does it show what? And does the new shortcut work?
Hi, @dfelinto !
The keyboard sensor detects the Numpad "," (comma) as "Numpad ." (dot/period).
It does not detect the Numpad "." (dot/period) at all (nothing happens, Blender keeps waiting for input with the "Press a key" message).
Since the key is not being detected, I cannot change the "View Selected" shortcut either (nothing happens, Blender keeps waiting for input with the "Press a key" message).
Just for safety, I tried a new keyaboard (hardware), and still get the same behavior.
Can you go here http://www.keyboardtester.com/
and hit the "." key on your Numpad and report what it shows?
Added subscriber: @LazyDodo
Is this still an issue?
For me to repro this, i'll probably have to match your keyboard settings in windows can you take a screenshot of this window on your windows installation?
Added subscriber: @mont29
More than a week without reply. Due to the policy of the tracker archiving for until required info/data are provided.
Added subscriber: @robertojonsan1
This comment was removed by @robertojonsan1
Added subscriber: @pablomlayfield
This comment was removed by @pablomlayfield
Added subscriber: @EvanSchmid
This comment was removed by @EvanSchmid
Added subscriber: @Jarvikts
This comment was removed by @Jarvikts
Added subscriber: @jacobsdevv
Hi,
Try keyboardtester.org - it will help you to fix all your keyboard related issues.
If your driver is not working properly, it will automatically detect it and tell you where the problem lies.
Added subscriber: @jhonesnow
This comment was removed by @jhonesnow
