Multi-dragging a user-defined property ignores 'PROPORTIONAL' option
Broken: 2.72 official
https://developer.blender.org/rB127330d6c added multi-drag with proportional scaling of values for e.g. Object.scale. A Python-defined property with options={'PROPORTIONAL'} does not scale proportionally however.
Run the following code and try the vector prop in Object tab:
import bpy
class HelloWorldPanel(bpy.types.Panel):
    """Creates a Panel in the Object properties window"""
    bl_label = "Hello World Panel"
    bl_idname = "OBJECT_PT_hello"
    bl_space_type = 'PROPERTIES'
    bl_region_type = 'WINDOW'
    bl_context = "object"
    def draw(self, context):
        layout = self.layout
        ob = context.object
        col = layout.column(True)
        col.prop(ob, "prop")
def register():
    bpy.utils.register_class(HelloWorldPanel)
    bpy.types.Object.prop = bpy.props.FloatVectorProperty(name="PROPORTIONAL", min=-10, max=10, subtype="XYZ", options={'PROPORTIONAL'})
def unregister():
    bpy.utils.unregister_class(HelloWorldPanel)
    del bpy.types.Object.prop
if __name__ == "__main__":
    register()
1.0
2.0
3.0
should become
2.0
4.0
6.0
but instead it will be
2.0
3.0
4.0
BTW: bla_rna.properties[...] does not seem to expose options
codemanx created this task.Oct 15 2014, 1:04 AM
codemanx raised the priority of this task from to 90.
codemanx updated the task description. (Show Details)
codemanx edited a custom field.
codemanx added a subscriber: codemanx.
