Changing vertex color alpha has no effect on transparency when using GLSL shading #42356
5 Participants
Reference: blender/blender#42356
Windows 7 64-bit
Intel HD Graphics 4000
Broken: 2.71
9337574
, 2.729e963ae
VertexAlpha.blend - Contains a plane that runs a script changing its vertex color and alpha values when the game engine is started
Start the game engine in the attached file and notice that while the vertex colors are changed, their alpha values are not (note that the actual alpha values of the vertices are changed and can be verified by calling print(vert.a), but changing the alpha value has no visual effect on the plane's transparency). If you change the shading mode from GLSL to Multitexture, you'll see that the transparency is now correctly changed.
Added subscriber: @mobious
Something else I noticed:
If you change the viewport shading to Solid instead of Textured/Material, the transparency is changed correctly when in GLSL. This has the opposite effect in Multitexture mode, e.i. the plane's transparency is not changed when using Solid viewport shading in Multitexture mode.
Added subscriber: @MikeErwin
Added subscriber: @hg1
Vertex transparency was never implemented in GLSL.
Vertex transparency actual only works in multitexture mode (OpenGL fixed function pipeline). If you change the viewport shading in GLSL to Solid it will also renders in shadeless multitexture mode. That is the reason why it works in GLSL to Solid.
For GLSL you only can use different materials for each color. But material color and alpha are also not changeable at the moment. You can use this only if you don't want change it.
The only possibility for the moment if you want to change multiple alpha values or colors for an object, is to split the mesh into more objects, parent it together and change the object color and/or alpha of it.
Added subscriber: @AngusHollands-4
Can this be closed?
This is a feature request. I moved it to our Game Engine TODO list: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/GameEngine
Closing the report. Thanks for your time.
