Wrong orientation for hair particles in Object or Group render mode #42397
Reference: blender/blender#42397
Any
Blender 2.72b - but it has been there for many releases, I f.E. found the same behaviour in Blender 2.66 and did not search further.
When creating a particle system in hair mode and "Object" render option, duplis show out with wrong orientation.
It is like if there was following transformation applied:
Thus, applying the inverse transformation (which is actually the same) would solve the problem. But it turns out that it is actually x and z vectors (in the code: vec and nor) that should simply be swapped.
N.B.: results are the same in Group render mode, all instances get this wrong orientation.
Open Blender
Edit the cube to have it dyssymetric (or add a Monkey instead, this is just for visualisation)
Add a plane, scale it in edit mode (just to have it easier to work on)
Add a particle system to it, choose the render option Object and set the Cube as the dupli object
Toggle the Rotation option to get the "cube" (or Monkey) in the same orientation as the original instance.
Now, switch the particle system to Hair mode
Again toggle the Rotation option in the render section
Both orientations (w/ or w/o Rotation) give bad orientation compared to those in Emitter mode.
Diff
Here is the .diff showing this swap:
blender_bke_hairpartori.diff
Added subscriber: @QuentinWenger
Oops, small error in the .diff, here is a new version:
(By the way: I cannot edit my own tasks !?)
Added subscriber: @mont29
(only devs can edit tasks themselves, iirc).
Lukas, this one sounds for you! ;)
Well, that's kind of strange... Am I not the owner of this task, as its author?
Added subscriber: @kevindietrich
Only the owner of a task can edit it, and by owner it is meant the one to whom the task is assigned (or the one who claims it), in this ticket it would Lukas. The author is just the one who creates it. This is some kind of Phabricator security thing. Changing this behavior is being talked upstream [here ]] and https:*secure.phabricator.com/D10012 . Then, everyone listed [ https://developer.blender.org/project/view/1/ | here can edit tasks without being the owner, not necessarily developers.
Ok, thanks for clarifying! ;-)
Please make a test file, otherwise i can't say if this is a bug or not.
Generally i think that hair and object instancing should not be combined and are incompatible features (big problem with particles), but that's just my personal opinion.
Ok, there you go:
272b_test_suzanne_particlesorientation.blend
In that file, there are Suzanne at the center and two planes on the left and the right; all three objects have the default orientations.
Each planes has a particle system, that is configured the same way, except:
What you can see is that particles on the right plane (hair mode) have an orientation that doesn't correspond to anything (you can find the relations in my first post). Even if you uncheck options "Rotation" in the dupli context, you don't get equal result; and obviously, emitter particles are correct, the others wrong.
Here is an example of videotutorial where the author complains about it... and he is not the only one.
https://www.youtube.com/watch?v=TJ_OcBh7F5I#t=1974
Particle rotation is utterly broken, no way this can be fixed properly without causing more issues. Has to be considered a todo, in the meantime i suggest not to try and match hair and emitter stuff, it's just not compatible anyway.
