Normals calculation breaking #42761
2 Participants
Reference: blender/blender#42761
Normals go inverted for no obvious reason and recalculation of the normals can fail to "fix" them
Load the attached blend
bad_normals.blend
Go to Edit Mode
Go Top View
Select all if not already selected
Press CTRL+N to fix the normals and observe how some inverted ones are fixed (by why not all considering those are repeated motif , their geometry/orientation is the same ?)
Press CTRL+N again and it's back to before
Making it so you need to fix those manually if you ever hope to add a solidify modifier by example (as the solidify follow the normals, you would end with very bad results if not all the normals are correct)
Fixing that manually is of course a solution on this kind of model because it's still small, but on more complex one, you can see how impractical this is
Added subscriber: @sanctuary
Thanks for the report, but this is not considered a bug.
Thing is, your rings are 100% flat, so there is no real 'inside' nor 'outside', so 'Recalculate Inside/Ouside' operator (called with ctrl-N) more or less gives random result in this case (probably driven by float precision limits). You just have to use Invert Normal operator on rings that are not OK after ctrl-N…
