Conflict particle/glossy node in Cycles #42787
Reference: blender/blender#42787
win7 64 nvidia gtx 780ti
Broken: 2.72b
Hi, sorry for my english. I have a quite light scene (508000 poly) and a particleSystem, 176 triagles applied to a tree.
If i render the scene without glossy surfaces on (glass, water ..) there are no problems and the calculation is done quickly. When i turn on the reflective surfaces my computer crashes in both calculation type: gpu (black screen) and cpu (render in the viewport blocked at simple 1 / ...)
Is sufficient to calculate the frames 1 (trees off) and 2 (trees on). If you wanto just turning off glossy material, the layer?s name is "group_vetri)test.rar
Added subscriber: @stefanocioncoloni
Added subscriber: @LukasTonne
I don't see any trees when going to frame 2, but i suppose
arancio.001
is the tree object used?Adding a glossy node to the common shader does not crash either.
How much memory do you have? Are you rendering on CPU or GPU?
Hi
i attach the correct file (sorry)
I have 16gb of system ram and 3gb of vram. I have used both systems (CPU/GPU) but the problem is the same.
test.rar
Sorry, i still can't reproduce the crash. This might be a windows issue (testing on linux) ...
hi,i have found the cause of the crash:
it's because of the refraction node in the acqua (water) material
if i replace it with a transparent node there aren't problems
thanks
