Glass Shader Renders Black in Cycles #43029
5 Participants
Reference: blender/blender#43029
I have made a character but for some reason the eyes renders black in Cycles? Each eye consist of two spheres, the scalera and the lens (cornea). Both are joined together and use different materials. The lens uses the glass shader with the IOR set to 1.45 and transparent shadows is checked. The eyes and the head are parented to a simple rig. Let me point out that the glass shader works fine in cycles until I parent the object to rig or to another object then it turns black. I even tried replacing the glass shader with refraction and its still very dark.
Acer Aspire 5040
CPU: AMD Turion™ 64 ML-32/ML-34 processor or higher with 512 KB or 1 MB of L2 cache, supporting AMD PowerNow!™ technology and AMD HyperTransport™ technology
Core Logic Chipset
VIDEO: ATI RADEON® XPRESS 200M GPU RS482M
RAM 1GB of DDR333 MHz
LCD, 1280 x 800 pixel resolution
HDD: 120GB
OS: Windows Xp Sp3 Media Pro, 32bit
Added subscriber: @RikSavage
Added subscriber: @mont29
Please always attach a .blend file to help reproducing the issue…
And I think I remember glass shader can be tricky to use in some cases? will let Cycles expert handle this, though.
I have also set light path to limited global illuminations then increased the transparency bounces to 10 and gloss to 8. I have tried turning the caustic off and on but it still looks dark. It has something to do with shadows.
Okay I will attach the file tomorrow afternoon since I am currenly using a mobile device.
Turns out the refraction caustics was unchecked though im not sure why that would matter but it becomes clear whenever enable it. Now the reflections looks strange.
A good idea would be the add a caustics option directly onto the glass shader. Makes life easier.
Please upload an example file if you think there is a bug or I have to close this report.
http://www.flipdrive.com/apps/mydrive/download?file=%2FKatie-Blackeyes.zip
Added subscriber: @Blendify
@RikSavage can you use a more common way of uploading a file, a way that does not require making a account for something. this saves our time
Sorry for the mixup but I tried to send the file directly to the cloud from my mobile device but it said that I must drag and drop it into the textbox. The problem is Androids D&D doesnt seem to work between pages. I tried copy&paste but no dice. So naturally I had the find an alternative method.
Here is an alternative link.
www.pasteall.org/blend/33601
@RikSavage I dont know if this is a bug but there other shaders other then glass. if you change the glass node to a transparent node you have know trouble
Added subscriber: @Sergey
Reuploading file here so it's not being lost:Katie-01-Cycles-Blackeyes.zip
Now, i don;t have a quick answer why the interior of the eye doesn't receive enough light, could be any of those:
The setup will likely be quite noisy anyway, so considering http://wiki.blender.org/index.php/Doc:2.6/Manual/Render/Cycles/Reducing_Noise#Glass_and_Transparent_Shadows is a good idea imo. It also makes your eye (well, not your but the character's you're working on) looking more or less expected.
I'll check what's exactly happening with light paths in this setup later.
Had a closer look now. It's indeed just a whole bunch of bounces required to render eye in a way you expect it to be. Setting light paths settings to full global illumination helps there, but it's still not really enough for your case.
Instead of bumping bounces even further just use the trick suggested in the link above. You can also do it glass for camera rays and transparent for others to reduce noise even further but keep glossy highlights on the eye.
In any case, don't really consider it a bug. Just tricky situation for path tracer. Thanks for the report anyway.
