bpy.ops.scene.new fails to set context when called from properties panel #43057
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#43057
Windows 7 x64, GPU irrelevant
Broken: 2.73 53ec177
Worked: never?
bpy.ops.scene.new fails to set the context when called from the properties panel. Apparently users have been [struggling ]] with this for [ http://blenderartists.org/forum/showthread.php?204227-Select-Scene-from-Python | years .
Blend file: bpy_ops_scene_new_bug.blend
Added subscriber: @MadMinstrel
Added subscribers: @ideasman42, @Sergey
@MadMinstrel, it is not recommended to use operators from other operators, especially if they're changing context. Using
bpy.data
is the way to go here.@ideasman42, i'm not sure if the case above is supposed to work, and also not sure why there's a difference depending on how the operator was invoked. What's your opinion here?
@Sergey In my particular case, I'm working on a baking addon. I have to prepare a scene before baking - merge/split objects, adjust UVs, modify shaders, run a compositor tree on the result once it's baked, etc. Lots of destructive stuff, which is why I'm doing it in a temporary scene. Since in the end I have to call bpy.ops.object.bake, and that relies on context, I don't think I can avoid setting it?
I'm not sure that this is supposed to work at all, but if not, it should at least generate an error, right? It'd be nice if it worked though. If it's not going to work, I'll have to move the bake button somewhere into the 3d View, and it sort of belongs in the Render tab.
This can probably be fixed, claiming.
This is nearly the same bug as blender/blender#43976
The problem here is its not assured that the buttons context scene is matching the screen's scene.
In fact its possible to pin a scene and in that case you don't really want to use the pinned scene either.
So the fix is not to use the button context at all, use
INVOKE_SCREEN
/EXEC_SCREEN
