Error when trying to render image with Cycles using GPU. #43126
Reference: blender/blender#43126
Windows 8.1.
ASUS - NVIDIA Geforce GTX 970. Driver Version: 347.09.
Broken: 2.73RC
I have not tried any other versions of Blender.
When I render my scene using the GPU I get the following message:
CUDA error: Launch exceeded timeout in cuMemcpyDtoH((uchar*)mem.data_pointer + offset, (CUdeviceptr)(mem.device_pointer + offset), size).
Error occurs when I try to render my scene using the GPU.
The attached file is setup to be rendered.
This has error has occurred in several of my projects including basic scenes that feature 1 character with no other objects present outside of lights and a ground plane.
I have used smaller tile sizes however this does not correct the issue. Blender_GPU_Error.zip
Added subscriber: @Dylan12-3
Added subscriber: @Sergey
I can not see the crash with the file you've provided. Presumably because it doesn't have any textures. Make sure they're all packed and provide updated file.
Also, there're some really similar reports (i.e. #43118) so instead of reporting same issue several times worth redirecting all the feedback in a single report.
Hi Sergey,
Thanks for your assistance.
If other users are having similar issues then there's no point in continuing with this thread.
Based on the other posts the issue seems to be driver related. Is there a recommended solution to this problem?
If this is a driver issue, are there any plans to update Blender to accommodate the driver (for instance in the next update of the software)?
That totally depends on what limitations the scene is running into. it's usually just impossible to avoid limitations set by the drivers.
I'm not sure what exactly the issue in your case without having a look into file which gives issues for you.
Also, did you try installing previous version of driver and see if it works?
I tried one of the previous drivers however it didn't fix the issue.
I'll upload the file with the textures again in the morning.
Thanks.
I had some difficulties with uploading the file so I've uploaded a different file that has a similar issue.
http://www.pasteall.org/blend/33705
Assuming that I did everything correctly it should have all of the textures saved.
Please let me know if you need anything else.
Hi Sergey,
Could you look at the file that I uploaded to try to identify what the problem is?
I really appreciate the assistance.
Thanks.
Not able to reproduce this here on Windows 7 using a GTX570
Is it possible that this could be related to the graphics card that I'm using? Other people have reported similar issues using that specific card as well as Windows 8.1.
I also should note that the error doesn't happen until it hits the 7th rendering tile.
Were you able to render the entire character?
Now i can reproduce the issue now and it is caused by limitation of GPU which is both used for display and compute. Basically video driver sets a time limit for kernel execution on GPU which are used for display. This means if tile computation is complex enough you'll run out of time rather quick.
Workaround could be to try making tile size smaller, but it'll have speed regression and will run out of tim eventually as scene becomes more complex. The only real solution is to use dedicated card for compute and less beafier one or display.
This time limit is dictated by the driver and blender can not do anything about this. SO thanks for the report, it's just how inperfect GPU compute world is..
Thanks Sergey.
My only question then is what would the difference be between Julian's GTX570 and my 970?
As far as I know the GTX970 should be able to handle the same workload as the GTX570.
I didn't even try to render till the 7th tile, as I assumed the crash would happen as soon as you start rendering. I can do that tomorrow if I don't forget to do so.
@Dylan12-3, it's not only about card, it's also about driver and operation system. Plus some difference in hardware clocks might have affect in here.
