Crash Upon Opening File #43283
Reference: blender/blender#43283
64bit Manjaro Linux, kernel 3.14.27
GeForce GTX 650 Ti, driver version 343.36
Broken: (example: 2.73
c24b694
, see splash screen)Short description of error
I lost about a day's worth of work after inadvertently introducing an object which would, with very specific circumstances, cause blender to crash if you opened the file or used the Undo function. After narrowing down the issue, it appears to occur with a specific object that uses the Mirror, Armature, Solidify, and Subdivision modifiers (in that order), and the crash condition is created when weights have been transferred to the affected object.
Just open this file: NoseScalesCrash.blend
Note 1: Splicing the problem object off into a separate file was tricky, since blender would sometimes crash when simply pasting a copy of the object!
Note 2: I also tested with the windows version of Blender, by running it under WINE. The crash still occurs there.
Added subscriber: @ZauberParacelsus
Added subscribers: @Sergey, @ideasman42, @mont29
Ouch, looks to me that .blend file is heavily corrupted… At least, that’s what I can guess from that backtrace:
P186: #43283
Looks like some pointer in the file has ugly bad value?
I don't think the problem is so much the file, but rather it may be some kind of mishandling with weight painting or deformation? The crash occurs after I transferred weights from one model to the problem model. But when I instead just created the DEF-head group and then set it to 100% on all vertices, there were no problems.
Okay, I've made another repro file. This one does not produce the crash, but rather sets the stage for the trigger conditions. For this I have used a different model off of blendswap, since I do not yet intend for the character models to be available in public.
File: NoseScalesCrashTest.blend
Repro: Open the file. The blend will be in Weight Paint mode. Go to the left and press Transfer Weights. From there, you have two ways to trigger the crash:
The file is corrupted beyond repairable state. We can not fix anything in blender in order to support this file working, But we should fix bug which lead to such a corrupted file.
For this we need exact steps of reproducing such a corrupted file from totally correct one.
@Sergey: Check my previous comment, before yours.
@ZauberParacelsus, save and reload makes no changes to internal data structures. Same applies to selection and undo. So the file is still somewhat corrupted and not good for tracking down actual bug.
So your comment before mine doesn't actually help.
Actually, I should point out that the problem begins with using the Transfer Weights function in weight painting mode.
Furthermore, I should clarify that I've been using a development build of Blender, where the Transfer Weights function appears to have been overhauled.
I'm betting that I ran into a new bug introduced in the Transfer Weights function, especially since the crash/corruption issue does not occur when I use the 2.73 release build.
Eeeeeeh, that’s a whole other topic!
Checking...
Further testing, and with new repro steps. It'll occur on ANYTHING you use Transfer Weights on.
New repro steps:
This issue was referenced by
119ff676e1
Closed by commit
119ff676e1
.@mont29: I just freshly compiled blender from git this morning. The crash no longer occurs with the original model(s) I discovered it on. However, it continues to occur with a slight variation on the repro steps I posted above:
Further, it seems like it will only crash sometimes on a bad saved file, but doing step 7 above on that file repros a crash, as will attempting to Transfer Weights again, or trying to remove a vertex group. In fact, every other thing I do on that file, even something as innocuous as entering edit mode, will trigger a crash. So, perhaps there is an unfixed code path that still has the issue?
@ZauberParacelsus cannot reproduce following steps you gave here… Unless you mean, you are still using a corrupted file? in this case, yes, even in a new scene issue will remain, but starting from scratch with startup file I get absolutely no crash here.
Issue repros on my build from just a couple hours ago that was compiled fresh off of git. However, the issue does not repro at all on the nightly I just downloaded.
Very weird :-/
what’s the hash shown on blender startup panel?
For the nightly, the hash is
6e97db7
. For the build I compiled myself (where the issue still repros partially), there is no hash. This is the output from git on the command line:That is pretty much exactly the same code… no reason to have that difference in behavior.
Maybe make a full rebuild (make clean, then usual build command)?
Deleted my blender source directory entirely, and redownloaded everything from git so that I had a clean slate. Issue no longer repros.
