Fix "Template Unsupported" #43461
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#43461
The pages for Node Controls, Using Nodes and Node Groups are blank (broken templates from wiki). This information should be added back.
The original content can be found here, though it's not ideal:
Added subscriber: @GregZaal
Added subscriber: @aobn
There is also missing content in Editor:
http://wiki.blender.org/index.php/Doc:2.6/Manual/Composite_Nodes/Editor
and Node Concepts:
also a reference to a bug in 2.44 which may no longer exist.
http://www.blender.org/manual/composite_nodes/types/filter/vector_blur.html#known-bugs
I'll just transfer the wiki content, initially. Later I'll try to improve it.
This issue was referenced by 205
Closed by commit rBM205.
Great, thanks! I did some improvements to 'Node Controls' (rBM207), but I'll leave the other two up to you.
Eventually these three pages should probably be moved to
/editors/node_editor/
Ok.
