Relative Paths #43546
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#43546
The use of relative paths in Blender (e.g.
//../textures/img.png
) is quite important and enabled by default, however it is not documented anywhere what exactly a relative path is, compared to the usual absolute paths (e.g./home/user/projects/test/textures/img.png
). It is not a common term for windows users and thus can cause some confusion.A page should be added to the Data System chapter which explains them properly, where they are used and what problems they might cause (e.g. moving a blend file using the OS's file browser will most likely break all texture and library paths in the blend file).
Then wherever relative paths are mentioned prominently, a link should be added pointing to this page.
Added subscriber: @GregZaal
Shall we assume readers know, or can find out, what a relative path is. It seems we shouldn't have to explain path hierarchy and define the terms.
Perhaps we can just briefly explain it - no need to go into too much detail. Might be a good idea to link to somewhere (e.g. wikipedia) that explains it more thoroughly.
This issue was referenced by 271
Closed by commit rBM271.
Very nice!
