Can't create FBX file that would import correctly smoothing in both Blender and Autodesk packages #43626
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#43626
Blender Build Bot master hash: 4ae6d58
I'm not able to export FBX file that can export sharp edges which will then import correctly in both Blender and Autodesk (Mudbox).
If I use while exporting Smoothing set to Off, FBX imports correctly to Blender but imports as fully smoothed in Autodesks software.
If I use Smoothing set to Edges it imports correctly to Autodesk but not to Blender.
Test file: lamp.blend
Added subscriber: @SirPigeonz
I strongly suggest you update your Blender from our buildbot, as I already said you in another report I updated how Blender FBX importer/exporter handle sharp edges, it now works OK (rechecked again here with your lamp).
As for 'Off' option (aka normals, have to rename that), I can't do much if mudbox does not reads normals…
