STL Import Script Scale option is strongly limited #43719
Closed
opened 2015-02-18 10:41:17 +01:00 by Zsolt Stefan · 5 comments
Windows 7
Broken: 2.73a
The STL import addon has a "scale" option, that resizes the geometry during import, but it's values are strongly limited. It has a lower limit of 0.01, so a simple conversion of units like millimeters to meters (0.001) is not possible, making the button not very useful.
This semms a very simple thing, an arbitrary limitation in the addon script. We use Blender to import CAD-data to visualize from STL files, which have units of millimeters, while we use Blender units of meters, meaning everything is imported 1000 times too big. The scale option during import could simply solve it with a 0.001 setting.
File --> Import --> STL. Settings are on the left bottom --> Scale --> Write 0.001 --> is reset automatically to 0.01.
**System Information** Windows 7 **Blender Version** Broken: 2.73a **Short description of error** The STL import addon has a "scale" option, that resizes the geometry during import, but it's values are strongly limited. It has a lower limit of 0.01, so a simple conversion of units like millimeters to meters (0.001) is not possible, making the button not very useful. This semms a very simple thing, an arbitrary limitation in the addon script. We use Blender to import CAD-data to visualize from STL files, which have units of millimeters, while we use Blender units of meters, meaning everything is imported 1000 times too big. The scale option during import could simply solve it with a 0.001 setting. **Exact steps for others to reproduce the error** File --> Import --> STL. Settings are on the left bottom --> Scale --> Write 0.001 --> is reset automatically to 0.01.
Author
Author
Added subscriber: @ZsoltStefan
Bastien Montagne self-assigned this 2015-02-20 10:04:55 +01:00
This issue was referenced by 81539bf9c2
This issue was referenced by 81539bf9c200602975610a032f63ad8e03bbeb77
Closed by commit 81539bf9c2.
Reference: blender/blender-addons#43719
