GHash Improvements #43766
1 Participants
Reference: blender/blender#43766
This task is related to work done on our GHash in temp-ghash-experiments branch.
Current Branch vs Master
This is a simple comparison between new code in branch and master one, using as close a possible same tests. Both are done using modulo, and no pre-reservation of buckets. Master uses load 3.0, new branch, load 0.75. New branch also adds hash stored in entries.
Notes:
no hash
in table above) gives nearly no speedup.Reducing Load
Here are the results of some tests, ran using this corpus (1 million of words, about 122MB of text), from corpora.informatik.uni-leipzig.de.
Inserted keys were: the whole text, all its lines, and all its words, leading to 2 917 605 entries.
Notes:
From that we can conclude (at least for now) that:
Also, we can see how important it is to pre-allocate (reserve) GHash buckets whenever possible. Resizing buckets is a very expansive operation. We can also see how interesting it can be to over-reserve buckets for better lookup times (see differences in lookup times between different % of load).
Storing Hashes
And now, here are some results with hashes stored in entries:
Benefits are obvious, non-reserved times are now quite close to reserve times even!
When Using Non-hashing Hash Functions
Yes, we do that in Blender - quit a bit actually!
Here we store 20M entries using raw pointers addresses as keys (from an array, so keys are consecutive addresses). No surprise here, a single modulo division shines, because (due to load < 1) it can perfectly spread all entries, while masking (since addresses are not small values) fails quite heavily. Note that even in this hyper-worst-case scenario, performances of masking are not that catastrophic.
In any other tested cases (consecutive ints starting from zero, and random ints), masking and modulo get very similar results.
So I think either we decide to stick to modulo, accepting the (more or less) 10% loss of speed, or we decide to switch to masking, which involves a careful check of all cases where we are currently using raw integers as hashes (e.g.
ghashutil_bmelem_indexhash()
,imagecache_hashhash()
, …). First solution looks simpler for now.About memory
Here are some (rough) estimations for 100M of entries:
In other words, all proposed changes approximately increase the memory footprint of GHash of 60%, and of GSet of 86%.
But our typical usage in Blender nearly never involves more than a few millions entries (usually much less actually), so I would not consider that an issue?
Added subscribers: @mont29, @ideasman42
Next things to check:
Added hashes to entries, this gives another nice boost in resizing, but also lookup (due to the fact comparing the hash avoids us many comparison on actual key value, which can be expansive e.g. with strings, I guess).
Also tried to increment sizes by two (instead of one) for small ones (below 16), but this did not showed any benefit when inserting into a non-reserved ghash, times were actually even worse (not sure why).
