Lambert shading error in blender internal #43789
Reference: blender/blender#43789
Windows 8.1, i5, Sandy Bridge
Broken: 2.73a
Lambert shading of face is wrong, changing different part of mesh corrects shading.
Open render_internal_diffuse.blend.
Press F12 to render.
Notice that both large faces are rendered differently.
Setup of scene and explanation why I think this is a bug
The sun is perfect white, and shines with 45 degree on the white object.
The material has no specular intensity and its diffuse color/intensity is perfect white.
By the Lambert model, the model should be shaded with cos(45 deg) = 0.707.
Only one of the faces is shaded with this intensity, the other is too dark (0.6224)
After removing one or both of the small faces right of the large faces, both large faces render with the correct intensity.
Added subscriber: @der_fab
Will have a look later.
Added subscriber: @ideasman42
Firstly, one of the faces has smooth set, and the other not, this is making the ray-bias treat the faces differently.
It seems to be working as intended, (but agree the final result is odd).
ob->smoothresh
set byset_phong_threshold
shade_one_light
is usingsmoothresh
whenMA_RAYBIAS
is set.I don't understand how faces, that are not connected to the problematic part, can have influence on its shading. Is this behavior documented somewhere?
We are using blender (internal) for lightmap baking and are getting different shadings on large areas due to this problem. Can this problem be fixed or should we work around it somehow? Is there an easy way to identify faces with different shading modes in the 3D View?
Thanks a lot!
Well, @ideasman42 is more or less explained everything already.
Seems there's a bit of confusion here tho -- one of big faces is set to smooth shading. It makes it shaded differently comparing to the one adjacent to it. Setting shading to flat to both big connected faces makes them shaded the same way.
I don't think it's a problem, just how shading works. Workaround and fix would be to set proper smoother flag.
Don't think there's existing way to show smooth faces, but it's easy to do with a python script.
Thanks for the report, but wouldn't consider it a bug.
