"Use Alpha" in Texture settings do not influence to Normal #43821
Reference: blender/blender#43821
All
Broken: up to 2.73a
Check box "Use Alpha" and "Use" on Image Sampling -> Alpha section of Texture panel do not influence to Normal
http://youtu.be/_M3o1kVQaso
bugUseAlpha-Normal.blend
Added subscriber: @VitaliiShmorgun
The images aren't included in your .blend, so could you use the "Pack All Into .blend" function (just use the search menu) and upload again?
Sorry. I forgot.
Added subscriber: @sindra1961
I made the png file which I added an alpha channel to from the jpeg file in the blend file which you attached.
I made it in image-editor of Blender.
It was different from the result that you reported.
The version that I used.
version 2.73 (sub 0), branch b'master', commit date b'2015-01-20' b'18:16', hash b'bbf09d9', b'Release'
version 2.73 (sub 9), branch b'master', commit date b'2015-03-02' b'00:05', hash b'56935e2', b'Release'
Result.blend
I may misunderstand the contents which you report.
My image actually png, as you can see in this screen capture
Your image work well, because you use RGBA with 16 bits float. It mean that this bug reproduced only with RGBA 8-bit per channel.
This help me in my work, but bug is still actual.
A result seems to vary according to a form of color depth of the png file so that you say.
Color_Depth_Diff.blend
Added subscriber: @Psy-Fi
Not sure how that should work... maybe @Psy-Fi does?
Those color channels are different when color depth is 8 or 16.
I'm not sure I understand what user would expect here.. The normal of the last image covering up the previous normal based on alpha or so?
Yes. Like with all other texture influence types. And like with 16 bits per channel normal map. It will be useful, if you want to combine couple normal map on one object and, may be, bake this result to new texture.
For me it can be workaround of this bug https://developer.blender.org/T43274
Bump maps are not really made to handle alpha, they are data, not color. And this is sort of understandable. Heights are not "transparent", this only makes sense for color. Initially the design was to use one channel per image if you check at the code (and postponed until we had proper support for those).
The pngs is a different issue but that works as expected too: Bump maps are loaded to OpenGL as data so they don't pass through our color management pipeline. 16 bit images are loaded as premultiplied in blender so they are multiplied by their alpha. During color management pipeline they are converted to straight space before being uploaded to OpenGL, unless they are treated as data. So for data textures, 8 bit pngs are already in straight space, and get the full opaque color, while 16bit pngs stay as premultiplied have the alpha taken into account.
What does work is a stencil texture, but that will also influence color textures. So I guess verdict here is that you can't really mix bump maps with a factor in the texture stack.
If you can do this in blender:
http://youtu.be/_UBrifFT-4w
using mask and node editor, then it is not a technical problem at all. Normal map data collect in 3 channels as a 3 component vector. Then if you have alpha channel in image, you can use this data for making similar effect.
Or you can fix this bug https://developer.blender.org/T43274 and I will be happy.
NormalMasking.blend
