[bmesh]calc_vert_angle does not return the correct value. #43904
Reference: blender/blender#43904
Windows XP/SP3 32bits
Broken: version 2.73 (sub 9), version 2.73 (sub 0), 2.71
Worked: unknown
This returns the correct value.
Added subscriber: @sindra1961
When edge sharing vertex is not only two, which edge is chosen?
In that case, can it appoint edge?
wrongbmeshangle.blend
This issue was referenced by
8638142c3b
Closed by commit
8638142c3b
.Added subscriber: @ideasman42
This wasn't working usefully.
Renamed to
calc_edge_angle
, now it takes an optional fallback value when the vertex doesn't have 2 edges connected. If no fallback is given it raises an exception.This issue was referenced by 720599e7a8994e73b47fba76cabe946ab241e1be
I thank for what you revised, but do not think that the correction has a meaning.
How long will vertex shared only to two sides exist?
There are four in Plane.
There is nothing in Cube.
I want you to think about how many such vertex there are in a primitive object.
The grand total of the angle between all edge sharing vertex.
Or an angle between edge chosen from edge which shared vertex.
I think that it can include a useful function.
I think that it is easy to use a latter function personally.
This value doesn't have a single/correct answer, since many disconnected faces can use a vertex.
You can for example - take the angle between the vertex normal, and one of the faces that use it. or all of them. then accumulate the difference (weighted by the face-angle).
Blender has a function called
BMVert.calc_shell_factor()
that does this, but it is just an approximation.You could do:
This comment was removed by @sindra1961
@Campbell: This is correct?
shellfactor.blend
@Campbell: Your correction seems to be wrong.
imcomplete.blend
The version that I confirmed
version 2.73 (sub 9), branch b'master', commit date b'2015-03-06' b'16:53', hash b'cf1227d', b'Release'
@JulianEisel (Julian Eisel):
I want you to open once again because a correction is not right.
I'd prefer to let Campbell decide that. We usually double check before reopening reports and he is the better man for that ;)
I understood it. I obey your decision.
re: comment @Sat, Mar 7, 6:23 PM
This is working as expected. A vertex exactly in the middle of 2 edges has 0deg angle. But when on the side of the face, that face-corner is 180deg.
Its just different way of interpreting the value.
@Campbell: I thank for your help.
This function was not the thing which I expected.
