Proportional editing lag #44035
Reference: blender/blender#44035
Win7 x64, GTX 460
Broken: 2.73, 2.74
Worked: 2.63
With proportional editing on, I get a few seconds freeze when activate translating (G); than after freeze,
everything goes ok. I thought that the problem was a large mesh, but 2.63 works great and without lags in the same file.
My "bugged" file is the one, I am working with. If it is possible, can i sent it in private and not give it to the world here?
Thank you!
Added subscriber: @MaximTkachenko
Please attach a file which shows the problem. With this kind of an issue you can probably re-create a file which has a similar issue.
Here it is
bug_prop.zip
If I remove part of mesh, it lags less.
But in older versions, it worked perfectly fast in any cases.
Added subscribers: @ideasman42, @JulianEisel
Can confirm that. Seems to be due to the amount of polys in the .blend. The question is: Why did it work in 2.63 but doesn't after that (didn't check 2.64 though)? @ideasman42, does that ring any bells for you? I can try to find the commit to blame if not.
Added subscriber: @candreacchio
checking through my old blenders....
r55260 works fine
r58134 has lag
Afraid this is working as intended.
Whats happening is:
The file attached in this report is a good example of worst possible case you could attempt to use connected-proportion-editing in.
I spent some time to optimize this case, and nearly got it a lot faster (nearly twice as fast). But theres still a very noticeable lag.
To support this case we would have to support re-calculating connectivity during transform, so it only calculates the data needed - then calculates more as the radius increases.
It would still be possible to take a mesh like this and shrink it down, or make the radius include the entire mesh (so its not fool-proof). But in cases like this where you edit only a portion of the mesh, it would resolve the issue.
Marking as TODO, since the code is not failing, this is just an extreme case which happens to be slow.
For now, in this case I can only suggest to workaround the issue - disable connected proportional-editing, or split out the geometry.
Removed subscriber: @ideasman42
