Compositing : Node Groups do not work correctly #44149
Closed
opened 2015-03-27 02:26:23 +01:00 by Carlo Andreacchio · 10 comments
Windows 7 x64 GTX580
Broken: 770b109
Worked: c31aae0
Node groups do not work correctly
  1. Open attached blend file
  2. render
  3. wait til it has finished & comped
  4. if it is all white, then it has the bug i am experiencing, if you see the rendered image normally, then the node group worked correctly
nodegroupbug.blend
**System Information** Windows 7 x64 GTX580 **Blender Version** Broken: 770b109 Worked: c31aae0 **Short description of error** Node groups do not work correctly **Exact steps for others to reproduce the error** 1. Open attached blend file 2. render 3. wait til it has finished & comped 4. if it is all white, then it has the bug i am experiencing, if you see the rendered image normally, then the node group worked correctly [nodegroupbug.blend](https://archive.blender.org/developer/F155412/nodegroupbug.blend)
Added subscriber: @candreacchio
Added subscriber: @mont29
Ugh, yes, getting a white result - and even got a crash just trying to add a viewer node (after going in and out of group - tab key)…
Added subscriber: @Sergey
So, here is how I get it crashing:
*Open the file
*Render (you can even interrupt render after a few tiles if you want)
*Go to node editor
*Enable compo nodes
*instant crash (see asan backtrace below).
P215: #44149
==14381==ERROR: AddressSanitizer: unknown-crash on address 0x62e000138408 at pc 0x4077384 bp 0x7ffcd2fdf6c0 sp 0x7ffcd2fdf6b8
READ of size 44240 at 0x62e000138408 thread T0
    #0 0x4077383 in node_preview_sync /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/node.c:1421
    #1 0x4077715 in BKE_node_preview_sync_tree /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/node.c:1440
    #2 0x43554d6 in local_sync /home/i74700deb64/blender/__work__/src/source/blender/nodes/composite/node_composite_tree.c:134
    #3 0x407ac0c in ntreeLocalSync /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/node.c:2028
    #4 0x22f8914 in compo_updatejob /home/i74700deb64/blender/__work__/src/source/blender/editors/space_node/node_edit.c:211
    #5 0x21a4bd4 in wm_jobs_timer /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_jobs.c:563
    #6 0x21d76b7 in wm_window_timer /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_window.c:1127
    #7 0x21d795e in wm_window_process_events /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_window.c:1160
    #8 0x21757b7 in WM_main /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm.c:484
    #9 0x217350d in main /home/i74700deb64/blender/__work__/src/source/creator/creator.c:1857
    #10 0x7fcad7f90b44 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x21b44)
    #11 0x216de2e (/home/i74700deb64/blender/__work__/build_cmake_dbg/bin/blender+0x216de2e)
0x62e000142ea8 is located 0 bytes to the right of 43688-byte region [0x62e000138400,0x62e000142ea8)
allocated by thread T119 here:
    #0 0x7fcade1bc885 in calloc (/usr/lib/x86_64-linux-gnu/libasan.so.1+0x54885)
    #1 0x4e8c82a in MEM_lockfree_callocN /home/i74700deb64/blender/__work__/src/intern/guardedalloc/intern/mallocn_lockfree_impl.c:286
    #2 0x3c3cd67 in PreviewOperation::initExecution() /home/i74700deb64/blender/__work__/src/source/blender/compositor/operations/COM_PreviewOperation.cpp:72
    #3 0x3b912cf in ExecutionSystem::execute() /home/i74700deb64/blender/__work__/src/source/blender/compositor/intern/COM_ExecutionSystem.cpp:166
    #4 0x3b8feba in COM_execute /home/i74700deb64/blender/__work__/src/source/blender/compositor/intern/COM_compositor.cpp:99
    #5 0x4356235 in ntreeCompositExecTree /home/i74700deb64/blender/__work__/src/source/blender/nodes/composite/node_composite_tree.c:232
    #6 0x22f8d73 in compo_startjob /home/i74700deb64/blender/__work__/src/source/blender/editors/space_node/node_edit.c:252
    #7 0x21a3768 in do_job_thread /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_jobs.c:328
    #8 0x4aaf424 in tslot_thread_start /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/threads.c:251
    #9 0x7fcadc6a20a3 in start_thread (/lib/x86_64-linux-gnu/libpthread.so.0+0x80a3)
Thread T119 created by T0 here:
    #0 0x7fcade18bbba in pthread_create (/usr/lib/x86_64-linux-gnu/libasan.so.1+0x23bba)
    #1 0x4aaf530 in BLI_insert_thread /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/threads.c:267
    #2 0x21a3ef2 in WM_jobs_start /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_jobs.c:411
    #3 0x22f90be in ED_node_composite_job /home/i74700deb64/blender/__work__/src/source/blender/editors/space_node/node_edit.c:298
    #4 0x23214ab in node_area_refresh /home/i74700deb64/blender/__work__/src/source/blender/editors/space_node/space_node.c:558
    #5 0x2e55ea3 in ED_area_do_refresh /home/i74700deb64/blender/__work__/src/source/blender/editors/screen/area.c:146
    #6 0x2185a10 in wm_event_do_notifiers /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:364
    #7 0x21757cf in WM_main /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm.c:490
    #8 0x217350d in main /home/i74700deb64/blender/__work__/src/source/creator/creator.c:1857
    #9 0x7fcad7f90b44 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x21b44)
SUMMARY: AddressSanitizer: unknown-crash /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/node.c:1421 node_preview_sync
Shadow bytes around the buggy address:
  0x0c5c8001f030: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x0c5c8001f040: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x0c5c8001f050: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x0c5c8001f060: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
  0x0c5c8001f070: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
=>0x0c5c8001f080: 00[00]00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x0c5c8001f090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x0c5c8001f0a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x0c5c8001f0b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x0c5c8001f0c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x0c5c8001f0d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Shadow byte legend (one shadow byte represents 8 application bytes):
  Addressable:           00
  Partially addressable: 01 02 03 04 05 06 07
  Heap left redzone:       fa
  Heap right redzone:      fb
  Freed heap region:       fd
  Stack left redzone:      f1
  Stack mid redzone:       f2
  Stack right redzone:     f3
  Stack partial redzone:   f4
  Stack after return:      f5
  Stack use after scope:   f8
  Global redzone:          f9
  Global init order:       f6
  Poisoned by user:        f7
  Contiguous container OOB:fc
  ASan internal:           fe
==14381==ABORTING
So, here is how I get it crashing: *Open the file *Render (you can even interrupt render after a few tiles if you want) *Go to node editor *Enable compo nodes *instant crash (see asan backtrace below). [P215: #44149](https://archive.blender.org/developer/P215.txt) ``` ================================================================= ==14381==ERROR: AddressSanitizer: unknown-crash on address 0x62e000138408 at pc 0x4077384 bp 0x7ffcd2fdf6c0 sp 0x7ffcd2fdf6b8 READ of size 44240 at 0x62e000138408 thread T0 #0 0x4077383 in node_preview_sync /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/node.c:1421 #1 0x4077715 in BKE_node_preview_sync_tree /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/node.c:1440 #2 0x43554d6 in local_sync /home/i74700deb64/blender/__work__/src/source/blender/nodes/composite/node_composite_tree.c:134 #3 0x407ac0c in ntreeLocalSync /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/node.c:2028 #4 0x22f8914 in compo_updatejob /home/i74700deb64/blender/__work__/src/source/blender/editors/space_node/node_edit.c:211 #5 0x21a4bd4 in wm_jobs_timer /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_jobs.c:563 #6 0x21d76b7 in wm_window_timer /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_window.c:1127 #7 0x21d795e in wm_window_process_events /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_window.c:1160 #8 0x21757b7 in WM_main /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm.c:484 #9 0x217350d in main /home/i74700deb64/blender/__work__/src/source/creator/creator.c:1857 #10 0x7fcad7f90b44 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x21b44) #11 0x216de2e (/home/i74700deb64/blender/__work__/build_cmake_dbg/bin/blender+0x216de2e) 0x62e000142ea8 is located 0 bytes to the right of 43688-byte region [0x62e000138400,0x62e000142ea8) allocated by thread T119 here: #0 0x7fcade1bc885 in calloc (/usr/lib/x86_64-linux-gnu/libasan.so.1+0x54885) #1 0x4e8c82a in MEM_lockfree_callocN /home/i74700deb64/blender/__work__/src/intern/guardedalloc/intern/mallocn_lockfree_impl.c:286 #2 0x3c3cd67 in PreviewOperation::initExecution() /home/i74700deb64/blender/__work__/src/source/blender/compositor/operations/COM_PreviewOperation.cpp:72 #3 0x3b912cf in ExecutionSystem::execute() /home/i74700deb64/blender/__work__/src/source/blender/compositor/intern/COM_ExecutionSystem.cpp:166 #4 0x3b8feba in COM_execute /home/i74700deb64/blender/__work__/src/source/blender/compositor/intern/COM_compositor.cpp:99 #5 0x4356235 in ntreeCompositExecTree /home/i74700deb64/blender/__work__/src/source/blender/nodes/composite/node_composite_tree.c:232 #6 0x22f8d73 in compo_startjob /home/i74700deb64/blender/__work__/src/source/blender/editors/space_node/node_edit.c:252 #7 0x21a3768 in do_job_thread /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_jobs.c:328 #8 0x4aaf424 in tslot_thread_start /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/threads.c:251 #9 0x7fcadc6a20a3 in start_thread (/lib/x86_64-linux-gnu/libpthread.so.0+0x80a3) Thread T119 created by T0 here: #0 0x7fcade18bbba in pthread_create (/usr/lib/x86_64-linux-gnu/libasan.so.1+0x23bba) #1 0x4aaf530 in BLI_insert_thread /home/i74700deb64/blender/__work__/src/source/blender/blenlib/intern/threads.c:267 #2 0x21a3ef2 in WM_jobs_start /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_jobs.c:411 #3 0x22f90be in ED_node_composite_job /home/i74700deb64/blender/__work__/src/source/blender/editors/space_node/node_edit.c:298 #4 0x23214ab in node_area_refresh /home/i74700deb64/blender/__work__/src/source/blender/editors/space_node/space_node.c:558 #5 0x2e55ea3 in ED_area_do_refresh /home/i74700deb64/blender/__work__/src/source/blender/editors/screen/area.c:146 #6 0x2185a10 in wm_event_do_notifiers /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm_event_system.c:364 #7 0x21757cf in WM_main /home/i74700deb64/blender/__work__/src/source/blender/windowmanager/intern/wm.c:490 #8 0x217350d in main /home/i74700deb64/blender/__work__/src/source/creator/creator.c:1857 #9 0x7fcad7f90b44 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x21b44) SUMMARY: AddressSanitizer: unknown-crash /home/i74700deb64/blender/__work__/src/source/blender/blenkernel/intern/node.c:1421 node_preview_sync Shadow bytes around the buggy address: 0x0c5c8001f030: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa 0x0c5c8001f040: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa 0x0c5c8001f050: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa 0x0c5c8001f060: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa 0x0c5c8001f070: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa =>0x0c5c8001f080: 00[00]00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x0c5c8001f090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x0c5c8001f0a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x0c5c8001f0b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x0c5c8001f0c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x0c5c8001f0d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Shadow byte legend (one shadow byte represents 8 application bytes): Addressable: 00 Partially addressable: 01 02 03 04 05 06 07 Heap left redzone: fa Heap right redzone: fb Freed heap region: fd Stack left redzone: f1 Stack mid redzone: f2 Stack right redzone: f3 Stack partial redzone: f4 Stack after return: f5 Stack use after scope: f8 Global redzone: f9 Global init order: f6 Poisoned by user: f7 Contiguous container OOB:fc ASan internal: fe ==14381==ABORTING ```
This issue was referenced by 8af5390968
This issue was referenced by 8af5390968a1c6971ba2e8b4f7621d4b8344fce8
Closed by commit 8af5390968.
This issue was referenced by 6410b1bd59
This issue was referenced by 6410b1bd59d8cf54ee619ffef8f8b14d0109b565
Reference: blender/blender#44149
