Different Pixel Aspect Ratio in Scenes of same Blendfile Causes Rendering Incorrect Section #44194
2 Participants
Reference: blender/blender#44194
Win7 GeForce 980
Broken: 2.73
Different pixel aspect ration of scenes in same Blendfile causes error in section and render size.
Create a{F156499} new scene with linked objects. Set Pixel aspect ratio to 2:1 (x:y). Divide resolution x by 2.
Go back into 1st scene, compositor. Create a new input -> renderLayer, Render.
The image of the 2nd scene is incorrect.
If you go to the 2nd scene and render, go back to the compositor in the 1st scene, the image is correct.
Added subscriber: @FrederikSteinmetz
Added subscriber: @Sergey
Compositor scene will render all the scenes with the same resolution. it might also need to use pixel aspect from the composite scene, but i'm not really sure it'll be a totally correct approach.
I want to render side by side, and the result of each "eye" will be shrinked to half resolution, so I didn't see a point in rendering it full res and shrink it, if I can use the aspect ratio to render it smaller. I guess I'll wright a script that renders the scenes one by one. Or is there a more simple approach?
EDIT: If I set the master scene to the same aspect ratio the resulting image will be too narrow, or is there a way to directly enlarge the render size after render?
You can use scale compositor node.
As for original report -- i'll check with our compositor team about making it so pixel aspect is used from the "master" scene. But apart form that you just need to be aware of blender's treatment of render settings when building your workflow.
After discussion with other devs it's not really so much a bug, just something you shouldn't be exploiting. With compositor becoming canvas aware it might be possible to map such cases in a reasonable way but in any case it's not a bug.
So thanks for the report, but archiving it now.
